Simplecity 27 #1 Posted June 20, 2024 Good Day In the process of correcting 60 years of grief that was inflicted on the 857, My question concerns the trip lever that engages/disengages the mower deck. Apparently the original spring was retired at some point and a hardware spring and eyebolt where installed. I know that one end of the spring attaches to the trip lever pivot, but where does the other end attach to? Pics would be awesome. Thanks to all who respond. Simplecity Share this post Link to post Share on other sites
Racinbob 13,193 #3 Posted June 20, 2024 Kinda hard to see but the pedal end of the spring is hooked to a cotter pin. The backside pin that it's hooked to goes down from the top like the one on this side thereby providing spring loading for the trip lever. 3 Share this post Link to post Share on other sites
Simplecity 27 #5 Posted June 21, 2024 Thanks to all who responded. I get how it attaches to the trip lever. Is it an eyebolt through the frame that anchors it? Here are the pics of how it looks now: Share this post Link to post Share on other sites
Racinbob 13,193 #6 Posted June 21, 2024 (edited) I'm not sure if they originally used an eyebolt. It may have just hooked to the frame. In either case it doesn't matter. Your problem lies in how you have it connected to the pedal end. Edited June 21, 2024 by Racinbob Share this post Link to post Share on other sites
peter lena 10,072 #7 Posted June 21, 2024 @Simplecity done a lot of , attachment related , detailing / function . always find an issue at belt driven pulley area , bearing is usually related culprit, also sloppy linkage , not snug , zero lubrication. interesting in that having had my attachment issues , once totally firmed up , regularly verified for function , the engagement is effortless / solid smooth . take the time to study , INTENDED function , then detail in starting point . @Racinbob noting your slightly loaded spring , is key to having a leverage start engagement . always go after every connection point , to enhance the engagement . washers, lube , evey hand off must continue its start .pull , pete Share this post Link to post Share on other sites
