stegs 327 #1 Posted June 18, 2024 anybody know the correct part number for a front wheel bearing on a c-101 I want to replace both front bearings, but i dont know if its the same size as a 416H i did a while back or if its a different size Share this post Link to post Share on other sites
peter lena 9,495 #2 Posted June 18, 2024 @stegs in addition to replacing bearings / also repacking them with a hi stress grease , pick up some steel washers , to shim up the LATERAL SIDE PLAY SHUCK . the combo of eliminating the side play wear , and better lube , has made my , wheel bearing issues go away , also a good time to raise suspension , and re grease spindle axel points , also have vinyl capped the top of spindle discharge point . what ever bearings you replace , look for a possible wide rubber side shield , thats easily removable , for clean out and hi temp / stress replacement . the difference between original and improved bearing , makes this a non issue . easy to do , pete Share this post Link to post Share on other sites
Ed Kennell 43,338 #3 Posted June 18, 2024 Amazon.com: XiKe 10 Pcs Flanged Ball Bearings ID 3/4" x OD 1-3/8", Applicable Lawn Mower, Wheelbarrows, Carts & Hand Trucks Wheel, Replacement 532009040, AM118315, AM127304, 10513, 251210 Etc. : Patio, Lawn & Garden 4 Share this post Link to post Share on other sites
peter lena 9,495 #4 Posted June 18, 2024 @Ed Kennell what's not to like ? great pricing , wide rubber side shields , local H/W store pullout drawer section for washers / shims , lucas green grease repack , solid smooth , pete 1 Share this post Link to post Share on other sites
Ed Kennell 43,338 #5 Posted June 18, 2024 Yep, Sealed bearings. Lift off the rubber seal, clean and regrease and shim tight per Petes post. I have them in use for years with no problems. Do not put grease in the hub zerk. BTW, You need 4 bearings to do one tractor. 2 1 Share this post Link to post Share on other sites
Handy Don 14,873 #6 Posted June 18, 2024 17 minutes ago, Ed Kennell said: BTW, You need 4 bearings to do one tractor. Share this post Link to post Share on other sites
