Mg181 4 #1 Posted June 12, 2024 1991 312-8 w 42inch RD mower owned since new. First time I ever remember the PTO lever disengaging randomly. At first I thought heavy thick grass, but it happens on fairly easy heights as well. Where should I look first to solve problem? Thank you Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,594 #2 Posted June 12, 2024 Tighten up the trunnion at the front of the pto lever two turns and if more is needed 1 turn at a time. You will see the edge of the friction material on the pto. When they slip they wear. Don't let it go too far so it scours the plate. 3 Share this post Link to post Share on other sites
Rick3478 444 #3 Posted June 12, 2024 It's an over-center design, usually pretty trouble free, but parts wear with age. Clutch disk wears thinner and lever bushings get sloppier, so if it isn't tight enough it may fall out of engagement. Check the condition of parts, if you're lucky may just need to tighten up a thread or two on the trunnion. Also possible to have something jammed so that it isn't moving to full on position, like sticks or other debris, bent safety switch. 1 Share this post Link to post Share on other sites
8ntruck 8,005 #4 Posted June 12, 2024 Check the C clip on the outside of the shaft that pushes the clutch to engage the PTO. If that clip comes out of the groove in the shaft, the shaft won't be pushing on the clutch to engage it. 1 Share this post Link to post Share on other sites
lynnmor 7,939 #5 Posted June 12, 2024 I bought two PTO bells from a good vendor on here, both had considerable wear on the outboard end, of course he replaced them. I have seen others with this strange wear and finally came to the conclusion that folks run the PTO's with the pins or clips wasted. Share this post Link to post Share on other sites
peter lena 9,341 #6 Posted June 13, 2024 @lynnmor agree with the functional detailing on the lever set up , go from the starting movement point , on the battery rail frame , area, washered up , every movement spot , steel washers / plastic , silicone grease . as said , that entire set up is a gold mine for improvement , also changed the trunnion to a HEIM JOINT , very solid smooth , pete Share this post Link to post Share on other sites
aemsee 93 #7 Posted June 21, 2024 I was just dealing with this after I installed my tiller for the spring planting. Then I realized I forgot to reinstall the lower clip on the pto horseshoe bar. Sucks getting old, lol. Share this post Link to post Share on other sites
tunahead72 2,558 #8 Posted June 26, 2024 I just encountered this same problem this afternoon while I was mowing. I heard a noise, and didn't realize at first what had happened, and then when I engaged the deck again the lever snapped back hard into my sore thumb, got my attention real fast! Tightening up the trunnion 2 turns like Garry suggested seems to have fixed the problem, but I do want to check things out more thoroughly before I mow with it again. @Mg181 Did you get your problem fixed? Share this post Link to post Share on other sites
