Jayoutdoors 107 #1 Posted June 2, 2024 Traded for this deck as mine has seen better days was under impression it was a 42 but when measuring blades they measrure like 46.5 end to end. any help would be greatly appreciated so i get the correct drive belt! Share this post Link to post Share on other sites
Rick3478 454 #2 Posted June 2, 2024 12 minutes ago, Jayoutdoors said: 13 minutes ago, Jayoutdoors said: Traded for this deck as mine has seen better days was under impression it was a 42 but when measuring blades they measrure like 46.5 end to end. any help would be greatly appreciated so i get the correct drive belt! 05-48MS02, according to the tag. 48" about 1982. Share this post Link to post Share on other sites
Jayoutdoors 107 #3 Posted June 2, 2024 ok i am right in my thinking then. thank you! now to find the lift rod from rear wheel shaft to mounting hardware Share this post Link to post Share on other sites
oldlineman 1,751 #4 Posted June 2, 2024 Yea thats a 48 in deck height adjustment on left side, 42 in is on the right side. 1 1 Share this post Link to post Share on other sites
peter lena 9,936 #6 Posted June 3, 2024 @Jayoutdoors would also bet those spindles are noisy / rough , you will have choices on that recovery , know what's coming up , get a penetrating oil soak going on the bottom of that , establish oil recovery first , just let it drink in the lube . if you can get the deck to spin , especially note the ROTATIONAL COLLECTIVE PULLEY DRAG / STRAIN ,NOISE , thats the real issue . the easier freer it spins is what you want . other choice is every related bearing to that mule drive set up , lubrication failure / or lack thereof , is the backbone to these decks . only insight / suggestions , hope it works out for you , pete Share this post Link to post Share on other sites
