Marv 991 #1 Posted May 26, 2024 I don't know how to label / caption pictures. I will just include them (hopefully in sequence). Since the input pulley is large, pulling it is a bit of a problem. I made a puller (plate) to be able to apply pressure to the hub. Using the plate for alignment I drilled two through holes in the pulley. That allowed for passing the puller bolts through the pulley and the plate. Now let me tell you, that hub was in love with the input shaft. The dummy who installed the pulley failed to use anti - seize on it. I was not happy with him. I performed many cycles of heat and penetrant on it and finally got it apart. Made a seal puller from a small blade screwdriver and pulled the seal. Cleaned things up and installed the new seal. All back together now, ready for the hood. In case you didn't guess it, I am that dummy. 3 5 Share this post Link to post Share on other sites
ebinmaine 73,597 #2 Posted May 27, 2024 On 5/25/2024 at 8:21 PM, Marv said: made a puller (plate) Nice work on that. On 5/25/2024 at 8:21 PM, Marv said: I don't know how to label / caption pictures. I will just include them (hopefully in sequence). I don't know how to do that either. What I usually do is select the pics from my device in the order I want them to set on this screen, then poke/click/touch each pic from below individually into this window. >>>> Then hit "Enter" 2 or 3 times to create a vertical space for adding lines of text. Hope this helps..... 1 Share this post Link to post Share on other sites
Handy Don 14,257 #3 Posted May 27, 2024 On 5/25/2024 at 8:21 PM, Marv said: In case you didn't guess it, I’d venture a guess that you are in excellent company here! 2 Share this post Link to post Share on other sites
peter lena 9,340 #4 Posted May 28, 2024 @Marv get er done ! https://defender.com/en_us/wpt-flax-packing-extractor-tool-size-0-10159?ut used these for years on tank drive repacking , punch a small hole in a seal side , screw in the puller , and pull it out , pete 1 Share this post Link to post Share on other sites
Woompa 2 #5 Posted March 9 I understand that the tine seal lip faces inward for the inner seal and outward for the outer seal, but which way should the lip face for the input shaft seal? 1 Share this post Link to post Share on other sites
Woompa 2 #7 Posted March 10 2 hours ago, Marv said: in Thanks! 1 Share this post Link to post Share on other sites
kpinnc 14,899 #8 Posted March 10 On 5/25/2024 at 8:21 PM, Marv said: I am that dummy I destroyed one of those pullies many years ago before online sales. Almost didn't find a replacement. I say you recovered very nicely! 1 Share this post Link to post Share on other sites
