Vintage_Wheel_Horse_Lover 21 #1 Posted May 15, 2024 im looking for this angle adjustment rod for the plow on my wheel horse b100 I circled it in the attached picture Share this post Link to post Share on other sites
Vintage_Wheel_Horse_Lover 21 #2 Posted May 15, 2024 or a way to make it out of a scrap chunk of metal 1 Share this post Link to post Share on other sites
peter lena 10,043 #3 Posted May 15, 2024 @Vintage_Wheel_Horse_Lover can easily pick up a piece of round stock , at big box or local h / w store , detailing in those plows for function is easy and really pays off in usage . hint , that related STEERING QUARRANT is a key area to improve . also build it up off the floor , on milk crates , so you can roller stool around it ,and look at what's going on . when suspended off floor , its exactly hanging like it would be under tractor , make sense ? dare I say it ? heim joints , blade swings without effort , pete Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,483 #4 Posted May 15, 2024 The 76-42BA01 blade does not fit the B-100 but the lever you need is likely the same. Share this post Link to post Share on other sites
rmaynard 17,560 #5 Posted May 15, 2024 So you are looking for items 17, 18, 19, 20, 21 & 26? 1 Share this post Link to post Share on other sites
Vintage_Wheel_Horse_Lover 21 #6 Posted May 15, 2024 1 hour ago, rmaynard said: So you are looking for items 17, 18, 19, 20, 21 & 26? yes Share this post Link to post Share on other sites
Vintage_Wheel_Horse_Lover 21 #7 Posted May 15, 2024 1 hour ago, peter lena said: @Vintage_Wheel_Horse_Lover can easily pick up a piece of round stock , at big box or local h / w store , detailing in those plows for function is easy and really pays off in usage . hint , that related STEERING QUARRANT is a key area to improve . also build it up off the floor , on milk crates , so you can roller stool around it ,and look at what's going on . when suspended off floor , its exactly hanging like it would be under tractor , make sense ? dare I say it ? heim joints , blade swings without effort , pete what do you mean by steering quarrant Share this post Link to post Share on other sites
peter lena 10,043 #8 Posted May 15, 2024 @Vintage_Wheel_Horse_Lover # 9 in diagram thats the swing point of the plow , you can easily improve that function and related linkages , in the reassembly , notice ist photo , the lower threaded rod ? heim joint ? that is connected to the steering quadrant , as is the squeeze lever that engages it . done a number of those plows , always corrected a chronic issue , rarely put anything back as I found it , make it better , pete Share this post Link to post Share on other sites
Vintage_Wheel_Horse_Lover 21 #9 Posted May 15, 2024 ok I will look into doing so. how would I put a handle in the round stock for the release Share this post Link to post Share on other sites
daveoman1966 3,884 #10 Posted May 16, 2024 Your B-100 tractor takes dozer blade 05-42BC01 so the schematic in your 1st question is wrong. It should be this one---or similar for long frame B & C series: Yu can easily make the INDEX LEVER #20 and the Upper rod #19. (#29 is in my pic too). The index handle #26 is OEM part # 5107--- ebay has them. Share this post Link to post Share on other sites
Vintage_Wheel_Horse_Lover 21 #11 Posted May 16, 2024 ok thank you Share this post Link to post Share on other sites
Vintage_Wheel_Horse_Lover 21 #12 Posted May 16, 2024 how tid u get the slight curve in it. and also how did u get the section where it jogs an inch or so over sorry for all the questions, I just turned 18 and have been around wheel horses my whole life. I have a collection of 2 workers number 3 is down. 3 is my grandpa's 71 charger 12 i believe it to be a bad coil and when it gets warm it also does not want to move and then I have like 6 for parts Share this post Link to post Share on other sites
daveoman1966 3,884 #13 Posted May 16, 2024 To answer your question(s): how tid u get the slight curve in it. and also how did u get the section where it jogs an inch or so over sorry for all the questions, First, drill the holes as I've shown. Then put the flat bar in a vise and make it red-hot where the two bends are. Do one, then the other to achieve about 2" between the two 90deg bends. While it is still red hot in the vise---after making the bends--- use some muscle and pull on the longest end to make the slight curve. Share this post Link to post Share on other sites
Vintage_Wheel_Horse_Lover 21 #14 Posted May 30, 2024 if it stays straight will it affect how it works Share this post Link to post Share on other sites
daveoman1966 3,884 #15 Posted May 30, 2024 Not sure--- no harm in trying. 2 hours ago, Vintage_Wheel_Horse_Lover said: if it stays straight will it affect how it works Share this post Link to post Share on other sites
Vintage_Wheel_Horse_Lover 21 #16 Posted May 30, 2024 ok where would I get the liincage Share this post Link to post Share on other sites
oliver2-44 11,722 #17 Posted May 30, 2024 If your not a fabricator, contact A-Z tractor and he can fix you up with excellent used parts. Share this post Link to post Share on other sites
