mikemc53 10 #1 Posted May 13, 2024 I'm looking to get a clutch plate (friction disc) for the pto clutch on my '78 C-81. Not sure of part numbers or exactly the best place to get one. Any help appreciated. Thanks. Share this post Link to post Share on other sites
ebinmaine 80,285 #2 Posted May 13, 2024 @76c12091520h Brian may be able to help you out. Share this post Link to post Share on other sites
ri702bill 12,816 #3 Posted May 13, 2024 Replaced mine with the later style slightly larger OD version from the 'Bay site..... 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,453 #4 Posted May 13, 2024 2 pages of info on the model https://www.wheelhorseforum.com/search/?q=81-08K801&quick=1&type=downloads_file Share this post Link to post Share on other sites
peter lena 10,015 #5 Posted May 13, 2024 @mikemc53 , just another thing bout rotational drag , its collective bearing movement points , that make up for PTO / MULE DRIVE MOVEMENT , how easily can you move the mule drive belt , by hand to the deck ? thats what tears up a clutch disc , might check out how the related bearings move . ease in my pto lever , smooth spin up , no whyining noise . lots of related , deck bearing / mule drive bearing , pulleys on this site . just a suggestion, pete Share this post Link to post Share on other sites
76c12091520h 4,282 #6 Posted May 13, 2024 See this and some of our other items in the vendor's section of the classifieds.... Share this post Link to post Share on other sites
midpack 1,148 #7 Posted May 15, 2024 I used one of these, they were really cheap off the jungle. I used JB weld or a heat resistant epoxy iirc. I had a PTO pulley assembly as a weight to try and hold the disc in place while it dried 2 Share this post Link to post Share on other sites
