peter lena 9,471 #1 Posted May 8, 2024 https://www.tractorsupply.com/tsc/product/phoenix-5-8-in-to-3-8-in-steel-sleeve-bushing-1185374?store=1490&cid=Shopping-Google- very often suggest a larger bearing / easy side grease shield access , for a clean out and a RE GREASE , with 550+ temp flash point grease ? hi stress, loading kills pulley bearings . this is a regular change out for me . duplicate original size / style of pulley , not w/h , so you can easily make the change. you can always paint it red ! the difference in rotational function is reliably amazing ! guy I sold a tractor to , thought clutch pedal , related linkages were broken , nope , they moved so easily / no bearing whine , he was mystified on how it worked so easily . easy to try out , in a problem area , pete 2 Share this post Link to post Share on other sites
peter lena 9,471 #2 Posted May 8, 2024 @ri702bill BTW , you could also pick up a 5/8 x 3/8 piece of piping to make up your bushings yourself / much cheaper . was pricing short / gage piping , just saw off a piece , angle grind the ends , press fit . once I started experimenting , with that replacement , never look at a pulley problem the same way , those pulleys will work without effort , go greasy , pete 2 Share this post Link to post Share on other sites
ri702bill 10,084 #3 Posted May 8, 2024 @peter lena I like it! Reminds we of my younger self working a side hustle with my FIL flipping used cars. He did the mechanical I did the body work. I had a work teeshirt made up that read "Cut it to lenght, beat it to fit, paint it to match"... !! 1 Share this post Link to post Share on other sites
peter lena 9,471 #4 Posted May 8, 2024 @ri702bill those bearings / related pulleys are such a common issue , once I started with them , also sloppy related linkage / connections , its just a regular thing to me . like going for a same pully type size , larger bearing , typically at tractor supply or on line , paint it red don't tell anyone , always good for a YOU CAN,T DO THAT , or a screaming PTO LEVER engagement , what could it possibly be ??? collective drag , should be removed / reduced , pretty easy once you remove the original set up , just me , pete 1 Share this post Link to post Share on other sites
