Spottedeventer 3 #1 Posted May 8, 2024 Hi, I blew the drive belt this evening and am having a tough time tracking one down online this evening. Does anyone have any suggestions ? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,875 #2 Posted May 8, 2024 I don't know if 314-8 models are all the same Transmission drive belt 78-7100 replaced by 7473 - HB x 81.9" or 5/8" x 81.9" Look for a 5/8" x 82" belt The sides of the belt must be cloth covered - no raw rubber 1 Share this post Link to post Share on other sites
Ed Kennell 43,931 #3 Posted May 8, 2024 Try Tractor Supply. The only belts I use. 3 1 Share this post Link to post Share on other sites
peter lena 9,594 #5 Posted May 8, 2024 @Spottedeventer, also check out the idler pulley on that , for easy rotation . small bearing is known for failure / rough intended function . would also get after related linkage points for lubrication , usually rusty / dry binding . like a penetrating oil tube spray . and a chassis grease in related chassis connections . also agree with @Ed Kennell on the belts , have them on , drive / deck / mule drive. very good function , pete Share this post Link to post Share on other sites
Spottedeventer 3 #6 Posted May 8, 2024 Thank you! I’ll check it out. A friend’s dad went over this tractor this winter. He loves these mowers 2 Share this post Link to post Share on other sites
John c 132 #7 Posted May 10, 2024 Gates or goodyear B82, should be able to find them nearly anywhere on line Share this post Link to post Share on other sites
squonk 44,976 #8 Posted May 12, 2024 On 5/10/2024 at 9:17 AM, John c said: Gates or goodyear B82, should be able to find them nearly anywhere on line A B82 has an inside circumference of 82" A 5L820 has an outside circumference of 82" The correct belt size is 82" outside. Share this post Link to post Share on other sites
John c 132 #9 Posted May 15, 2024 I didn't know that....... my 314-8 runs just fine with a B82 Share this post Link to post Share on other sites
