squonk 47,989 #1 Posted May 4, 2024 May is truck maintenance month with the big trip to PA in June. I knew I had a rear axle seal starting to leak on my 2013 GMC so I had it in the shop for the state inspection and got the seals done. I have been seeing posts on FB of burned up belt idler and tension pulleys. Plastic pulleys all melted. I remember from my Napa days of Ford Taurus' being towed off the Thruway with blown idlers. I decided to check mine. The metal idler pulley was fine but the plastic tensioner pulley rattled like a cold Detroit Diesel. So I installed a new Napa Gates tensioner with a metal pulley and a new belt. Popped the seal out of the old pulley and lets just say the grease had left the building! 6 3 Share this post Link to post Share on other sites
Pullstart 71,157 #2 Posted May 4, 2024 You got enough room in that half ton for all the crap you sold me? 5 Share this post Link to post Share on other sites
clueless 3,437 #3 Posted May 4, 2024 You should of keep the Yota, but nooooo you had to have a GMC vehicle. 3 Share this post Link to post Share on other sites
squonk 47,989 #4 Posted May 4, 2024 37 minutes ago, Pullstart said: You got enough room in that half ton for all the crap you sold me? Gonna have some stuff of Randy's as well. May have to utilize the glove box and center console! 1 1 Share this post Link to post Share on other sites
squonk 47,989 #5 Posted May 4, 2024 1 minute ago, clueless said: You should of keep the Yota, but nooooo you had to have a GMC vehicle. The Tojo would have had close to 300,000 miles by now if I kept it. Would have been time to change the air filter. But I doubt my back would have been able make the trip. Those rice burner seats were killers. GMC has a Barcalounger! 3 Share this post Link to post Share on other sites
CCW 1,519 #6 Posted May 4, 2024 58 minutes ago, squonk said: The Tojo would have had close to 300,000 miles by now if I kept it. Would have been time to change the air filter. But I doubt my back would have been able make the trip. Those rice burner seats were killers. GMC has a Barcalounger! Yeah, we are getting a bit older and fussier about comfort. 1 Share this post Link to post Share on other sites
ebinmaine 80,456 #7 Posted May 4, 2024 1 hour ago, squonk said: Gonna have some stuff of Randy's as well. May have to utilize the glove box and center console! Got an engine for the BBT too! Nice catch on that pulley Mike! Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #8 Posted May 4, 2024 If you run out of space tie Randy to a front fender. Share this post Link to post Share on other sites
squonk 47,989 #9 Posted May 4, 2024 35 minutes ago, ebinmaine said: Got an engine for the BBT too! Nice catch on that pulley Mike! Have you decided who's picking up that engine for you? 1 Share this post Link to post Share on other sites
ebinmaine 80,456 #10 Posted May 4, 2024 1 minute ago, squonk said: Have you decided who's picking up that engine for you? @wallfish has volunteered. If for any reason that doesn't pan out I believe @PWL216 would also be willing. 1 Share this post Link to post Share on other sites
clueless 3,437 #11 Posted May 5, 2024 4 hours ago, squonk said: The Tojo would have had close to 300,000 miles by now if I kept it. Would have been time to change the air filter. But I doubt my back would have been able make the trip. Those rice burner seats were killers. GMC has a Barcalounger! Yep, like most of us, comfort over quality. Let us know how comfortable that Barcalounger is at 275,000 miles, if it makes it that far 1 1 Share this post Link to post Share on other sites
Beap52 2,440 #12 Posted May 5, 2024 Good catch on the tensioner. The fellow who was responsible for engineering early 90's GM pickups rear differential brackets must have went fishing instead of attending class. The U bolts pass through a cup that catches and holds road debris including dirt and salt resulting in the U bolts rusting and potentially breaking allowing the rear axle to be left behind. I discovered this on a '94 Chevrolet pickup and the '92 GMC that I am currently driving needed the U bolts replaced. I saw an early 90's pickup in a ditch with the rear axle kittywampus. No doubt he wasn't aware of rusted U bolts. 1 Share this post Link to post Share on other sites
