giant_g2 24 #1 Posted May 4, 2024 Hi all, I recently got a 48" plow that is missing two parts. They seem like easy parts to make and fairly expensive to buy. One is the angling rod part 104338. Seems like I could just bend a steel rod. I think I just need approximate rod diameter and the approximate lengths of each straight. I'm also missing the lift link part 105052. I think for this all I need is the center to center distance of the two metal rods. Share this post Link to post Share on other sites
ebinmaine 81,282 #2 Posted May 4, 2024 1 minute ago, giant_g2 said: angling rod IMHO you're FAR better off building one from two heim joints and some threaded rod or threading the ends of a 1/2 rod. That will greatly reduce the looseness of the connection between handle and blade. 3 minutes ago, giant_g2 said: lift link Solid link? Are you using the plow on a hydro lift or manual lift? 1 1 Share this post Link to post Share on other sites
Racinbob 13,290 #3 Posted May 4, 2024 Here ya go. Front Blade Lift Links - Misc. Items - RedSquare Wheel Horse Forum 12 minutes ago, ebinmaine said: IMHO you're FAR better off building one from two heim joints and some threaded rod or threading the ends of a 1/2 rod. That will greatly reduce the looseness of the connection between handle and blade. Solid link? Are you using the plow on a hydro lift or manual lift? I didn't really think about the tranny difference Eric. I've always like the longer rod for a solid connection (downforce) but that's been on manuals. I was thinking about using the blade on my latest acquisition since it's a hydro. I need to rethink that. 1 1 Share this post Link to post Share on other sites
ri702bill 13,396 #4 Posted May 4, 2024 (edited) As Eric said, Heim Joints are the way to go. The rod is 1/2" diameter, about 36" long. No need to bend it if you use the spherical joints. Used with hexbolts, Nylock nuts and washers as spacers to prevent binding. Edited May 4, 2024 by ri702bill 4 1 1 Share this post Link to post Share on other sites
giant_g2 24 #5 Posted May 4, 2024 Thanks so much! 1 Share this post Link to post Share on other sites
ebinmaine 81,282 #6 Posted May 4, 2024 @ri702bill Good pics! 6 minutes ago, Racinbob said: Here ya go. Front Blade Lift Links - Misc. Items - RedSquare Wheel Horse Forum I didn't really think about the tranny difference Eric. I've always like the longer rod for a solid connection (downforce) but that's been on manuals. I was thinking about using the blade on my latest acquisition since it's a hydro. I need to rethink that. It's fine as long you're prepared to adjust the lift when needed. Depending on driveway surface that could be next to never, or constant. Ours is pretty rough so I wouldn't consider a solid link viable on a hydro lift. On a smooth concrete drive it would likely be helpful. In my particular case the 60" blade with the super heavy duty cutting edge is so heavy I don't need down pressure. 3 Share this post Link to post Share on other sites
JoeM 10,318 #7 Posted May 4, 2024 33 minutes ago, giant_g2 said: One is the angling rod part 104338. Seems like I could just bend a steel rod It can and works fine. I think the rod is 42" center to center. Just to make sure, you can put your blade straight and the handle straight and measure. One small tip I have found helpful, some over tighten the center pivot bolt. There needs to be a little play there to allow the blade to float a bit. Makes it much easier to turn and contacts the ground better when angled and used on uneven surfaces. 3 Share this post Link to post Share on other sites
Ed Kennell 47,952 #8 Posted May 4, 2024 (edited) I don't use solid links on my 42 and 54 inch plows that are both on hydro tractors. IMO, hydro lift is a must for snow removal. I can and do use the frame side sway prevention rod to set a minimum height when plowing the stone road. The rod has a series of holes that I can use a hairpin clip and washer to set the blade minimum height at 0,1",2",3", etc ground clearance when I don't want to pick up stones. Edited May 4, 2024 by Ed Kennell 1 Share this post Link to post Share on other sites
JoeM 10,318 #9 Posted May 4, 2024 6 hours ago, JoeM said: 42" center to center Mistake that is the measurement for the xi rod. 31 1/2 is the correct measurement my bad Share this post Link to post Share on other sites
JoeM 10,318 #10 Posted May 4, 2024 4 hours ago, Ed Kennell said: frame side prevention rod Not sure what that is, got some pics? Share this post Link to post Share on other sites
Moparfanforever 940 #11 Posted May 4, 2024 35 minutes ago, JoeM said: Not sure what that is, got some pics? Share this post Link to post Share on other sites
Ed Kennell 47,952 #12 Posted May 4, 2024 1 hour ago, JoeM said: Not sure what that is, got some pics? 1 hour ago, Moparfanforever said: Plow side sway or push...sorry I missed a word. Everyone has a version of this, but I also use mine to set control the minimum plow blade height. See post #14 1 Share this post Link to post Share on other sites
