Fordiesel69 271 #1 Posted May 2, 2024 I need to start repairing my decks as I have no spares. On 2 of my older style 42" side discharge decks, it does not have the half round bar to protect the front edge from getting bent. I have a local steel company I can source the bar stock from but have no shop or machines to bent it. Can I just weld and bend by hand as i go? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,875 #2 Posted May 2, 2024 I have added 1/2" round bar and did as you suggest. If necessary a MAP torch is plenty to heat on the sharper bends.. 1 3 Share this post Link to post Share on other sites
lynnmor 8,303 #3 Posted May 2, 2024 Buy a longer length than you need. Take the deck and steel bar out in the woods and find a tree crotch for your bending jig. It ain't rocket surgery. 4 Share this post Link to post Share on other sites
mrc 1,022 #4 Posted May 2, 2024 2 or 3 pairs of vise grips help too. i used rebar on a friends deck Share this post Link to post Share on other sites
peter lena 9,594 #5 Posted May 2, 2024 @lynnmor say what ? bending steel bar on a tree , ? should be talking to you more often ! you cant do that ! only kidding , makes sense to me to bend something on an immovable round based object ? sch 40 1" pipe as a helper ? watch out , they will be coming for you , thanks for the refreshing idea , pete Share this post Link to post Share on other sites
Lee1977 7,464 #6 Posted May 4, 2024 (edited) I used 3/8" cold roll a cross the front clamp it with vice grips weld the end. then pull it tight clamp it and weld another spot. I welded about every 4" then I turned it over welded the same spots on the bottom. I was bending the deck from hitting roots avove the ground, haven't bent it since. Across the closed end I used 1/8 x 1" flat. This is a 47 year old deck. Edited May 4, 2024 by Lee1977 2 Share this post Link to post Share on other sites
John c 132 #7 Posted May 4, 2024 acetylene torch and some used motor oil to quench it in would be ideal if you can, I'd probably do it in 2 halves and put the seam behind the middle gage wheel. Don't have an acetylene rig ???? What better time than this to add a tool to your arsenal. Share this post Link to post Share on other sites
kpinnc 16,328 #8 Posted May 4, 2024 10 hours ago, Lee1977 said: I used 3/8" cold roll a cross the front clamp it with vice grips weld the end. then pull it tight clamp it and weld another spot. I welded about every 4" then I turned it over welded the same spots on the bottom. I was bending the deck from hitting roots avove the ground, haven't bent it since. If you use this method, you don't need additional heat. As has already been said, use a longer piece than needed. When you make the last weld, cut off the excess. Share this post Link to post Share on other sites
