peter lena 9,898 #26 Posted May 26, 2024 @Horse46 went over to graphite spray , on starter gear to flywheel , also that starter solenoid screw flight , insures engagement ease , have added numerous battery ground based connections to all my stuff , easy to make up , also like the industrial bolt on electrical lugs . allows you to ground as you go on frame . BTW the engine cooling " tinns " are terrible for ground connection , your fuel issue , sounds like dirty tank , and related . done a number of total fuel refits , never put it back exactly as it was , fuel hose break down is common , use 2 filters , one close to tank another close to carb , personally add a fuel storage additive , STA BIL to every drop of fuel , no more debris ! sounds like you have a number of issues going on , thats the dark cloud over you , have to ELIMINATE the worst , and go from there . can only suggest and send you the best luck on yours , pete Share this post Link to post Share on other sites
