KW88 33 #1 Posted April 27, 2024 What have you guys done to replace 312-8 with a stack exhaust/ pipe? Appears I gotta 1-3/8 OD off the 12hp kohler... Share this post Link to post Share on other sites
KW88 33 #2 Posted April 27, 2024 4 minutes ago, KW88 said: What have you guys done to replace 312-8 with a stack exhaust/ pipe? Appears I gotta 1-3/8 OD off the 12hp kohler... I'm not worried about noise, just want like a small stack like a foot or two up Share this post Link to post Share on other sites
SylvanLakeWH 30,593 #3 Posted April 27, 2024 @jimkemp sells them... 1 Share this post Link to post Share on other sites
ebinmaine 77,332 #4 Posted April 27, 2024 8 hours ago, KW88 said: 1-3/8 OD That's an NPT pipe thread size. Likely 1-1/4". I've done several Kohler single cylinder engine exhausts using a 45⁰ elbow attached to appropriate length double male pieces. One to the head and one to the muffler. For a muffler I've used a Cub or Gravely aftermarket replacement. Either works well and can be turned facing up. On top of the muffler you can get a metal bathroom drain pipe and trim as desired. This gives you the ability to have a turnout bend and point the end where you want it. Share this post Link to post Share on other sites
rjg854 12,843 #5 Posted April 27, 2024 This is what he makes, they look like this. 1 Share this post Link to post Share on other sites
RED-Z06 2,716 #6 Posted April 28, 2024 1" NPT into a 45⁰ elbow pointed straight out, into a 4" straight pipe, into a 90⁰ elbow up...into a "Kohler cub cadet" muffler. https://youtube.com/shorts/V6y0zUDAdWI?si=y4DPgo1nZ-8go2uR 1 Share this post Link to post Share on other sites
ebinmaine 77,332 #7 Posted April 28, 2024 5 hours ago, RED-Z06 said: 1" NPT into a 45⁰ elbow pointed straight out, into a 4" straight pipe, into a 90⁰ elbow up...into a "Kohler cub cadet" muffler. https://youtube.com/shorts/V6y0zUDAdWI?si=y4DPgo1nZ-8go2uR That's the way. You can use the above mentioned Gravely Muffler in the same set up. Also, where the 4" pipe is listed, I've used a longer section either from engine to elbow or elbow to muffler to add a little clearance for the hood paint. Share this post Link to post Share on other sites
tmorriss 3 #8 Posted April 29, 2025 HI Folks. I have a similar situation with my 1987 312-8 , with a Kohler Magnum 12 engine. THe original muffler is falling apart and cant be repaired. I now use this machine to mow areas where I don't want to take my new one, and I'd like to fix the muffler as cheaply as possible. What you have mentioned above sounds promising as the current manifold is a 1 7/16 OD that accepts the factory clamp on. However, I really don't want the big muffler and long stack. Does anyone know(or done) something similar by just removing the manifold pipe, screwing in an appropriate sized pipe with two male ends and then screwing on one of those small,round screw on mufflers? OR will this type of muffler cause performance issues with the engine, loss of power etc? Thanks in advance Share this post Link to post Share on other sites
ebinmaine 77,332 #9 Posted April 29, 2025 2 hours ago, tmorriss said: HI Folks. I have a similar situation with my 1987 312-8 , with a Kohler Magnum 12 engine. THe original muffler is falling apart and cant be repaired. I now use this machine to mow areas where I don't want to take my new one, and I'd like to fix the muffler as cheaply as possible. What you have mentioned above sounds promising as the current manifold is a 1 7/16 OD that accepts the factory clamp on. However, I really don't want the big muffler and long stack. Does anyone know(or done) something similar by just removing the manifold pipe, screwing in an appropriate sized pipe with two male ends and then screwing on one of those small,round screw on mufflers? OR will this type of muffler cause performance issues with the engine, loss of power etc? Thanks in advance I have used the Gravely style muffler on several tractors now. 2 16 horse and one 12 horse. Compact. 90° Bend built in. Rugged. Decent sound. No restriction. Share this post Link to post Share on other sites
