Bow_Extreme 535 #1 Posted April 25 Well, I decided to try something different. Bent a piece of 1/2” conduit and ran the wires that normally go overtop of the engine, through the conduit. Now it needs powder coat. 4 5 Share this post Link to post Share on other sites
ebinmaine 63,303 #2 Posted April 25 I like that! May have to borrow this idea sometime... 2 Share this post Link to post Share on other sites
ri702bill 7,374 #3 Posted April 25 Nice - as long as there are chaffe proof grommets at both ends. That conduit is a direct ground. 1 Share this post Link to post Share on other sites
Bow_Extreme 535 #4 Posted April 25 1 hour ago, ri702bill said: Nice - as long as there are chaffe proof grommets at both ends. That conduit is a direct ground. Exactly. The upper end is complete with the wiring loom pushed inside the connector and clamped. I have to do the starter end now. 3 Share this post Link to post Share on other sites
peter lena 8,098 #5 Posted April 25 @Bow_Extreme think anything that helps out the electrical / complexity of those twins is worthwhile , good idea , pete 2 Share this post Link to post Share on other sites
Pullstart 59,842 #6 Posted April 25 With the belt guard and PTO assembled, you’ll hardly notice it’s different! Great mod Matt! 3 Share this post Link to post Share on other sites
peter lena 8,098 #7 Posted 10 hours ago @Bow_Extreme good common sense there ! regularly use a REPEDITAVE FAILURE , as your guide , eliminate it ! getting wiring away from heat , take advantage of that cooler air flow , notice your PTO hitch pin clip , was regularly buzzing / noisy ,? put a light extension spring from that to , lower swing arm , hitch pin clip , no more noise , keep on improving , good for you , pete Share this post Link to post Share on other sites
