Greg Barnett 1 #1 Posted April 11, 2024 My tractor will not go into gear. If its turned off i can move the shifter thru the gears but as soon as i turn it on it won't move. I was able once to get it in gear but i had to force it alittle but then it would not stop. I had to turn it off. Can anyone help me with this please. Thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,013 #2 Posted April 12, 2024 Sorry have zero experience with this model. Sounds like your drive belt is not stopping when you apply the clutch. There are belt guides when the belt is loose that are intended to force the belt slack to the engine pulley so it can slip. These guides should just clear the belt when it is tight. An incorrect drive belt length may be the problem if just replaced. A service bulletin on the subject Apologize for the poor quality pictures in this one Share this post Link to post Share on other sites
Greg Barnett 1 #3 Posted April 12, 2024 Thank you for your advice. I will look into this today. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,013 #4 Posted April 12, 2024 We do not have the 1989 operator manual Share this post Link to post Share on other sites
