Keaton 466 #1 Posted April 9, 2024 I have been looking for front tires for my lawn ranger and I have came up with nothing, I also need new spindall but one of them is a cub spindall so I think I will get another one of those, they are 3/4 bore 4.10 or 3.50 x 4 any help will be appreciated, thanks - Keaton Smith and I cannot reuse the old ones because they did not ever Greece the tires and it worn down the spindall and the spindall is all messed up and the 3/4 bore is more like a 1 inch hole 1 Share this post Link to post Share on other sites
Pullstart 68,529 #2 Posted April 9, 2024 The spindle is part of the axle. Are the wheels messed up? Did they have bushings you could drive out in favor of bearings? They are a standard size, like 1-1/4” or 1-3/16” OD with a 3/4” ID. Share this post Link to post Share on other sites
Keaton 466 #3 Posted April 9, 2024 (edited) @Pullstart the wheels are steel sleeves that will not come out, I tried the spindall is wore down like the picture below, mine is not that bad, but the other one is a yellow spindall so I'd guess it is a cub spindall Edited April 9, 2024 by Keaton 1 Share this post Link to post Share on other sites
Achto 30,205 #4 Posted April 9, 2024 (edited) 2 hours ago, Keaton said: I have been looking for front tires for my lawn ranger and I have came up with nothing Here is one source for tires. If you need the rims as well, you can switch the 5/8" id bearings out for 3/4" id ones. https://www.millertire.com/categories/lawn-garden-tires/3-00-4/ https://www.millertire.com/categories/lawn-garden-tires/4-10-4/ Edited April 9, 2024 by Achto Share this post Link to post Share on other sites
Keaton 466 #5 Posted April 9, 2024 and does someone know the color the lawn ranger rims are supposed to be , bright white, a darker white or almond? Share this post Link to post Share on other sites
Achto 30,205 #6 Posted April 9, 2024 3 hours ago, Keaton said: and does someone know the color the lawn ranger rims are supposed to be , bright white, a darker white or almond? That one kinda opens a can-o-worms. I prefer an International Harvester off white, others prefer a bright white. Here is a pic of my 701 with IH off white rims. Share this post Link to post Share on other sites
Keaton 466 #7 Posted April 9, 2024 @Achto I also have a 701, I need a belt cover for it it is my favorite tractor as of now. and I will look for some paint the next time i am out 1 Share this post Link to post Share on other sites
kpinnc 16,202 #8 Posted April 10, 2024 4 hours ago, Achto said: That one kinda opens a can-o-worms. I prefer an International Harvester off white, others prefer a bright white. I think older machines up until at least the late 60s used a darker beige anyway. Regardless, I agree it looks better on round hoods. Share this post Link to post Share on other sites
32percenter 6 #9 Posted April 10, 2024 I would weld up those spindles and then grind them to fit new ball bearings pressed into the lawn ranger wheels Share this post Link to post Share on other sites
peter lena 9,559 #10 Posted April 10, 2024 @Keaton https://www.google.com/search?q=wheel+horse+front+axel+spindles&rlz=1C1CHBF_enUS866US866&oq=wheel+horse+front+axel+spindles+&gs_lcrp=EgZjaHJvb , make things easy , replace , new RE GREASED , bearings . your set up is long past its life . regular service , would have eliminated it . also shim up spindles to wheel , that wheel shucking , side play , destroys bearings , pete Share this post Link to post Share on other sites
