JimSraj 593 #1 Posted April 8, 2024 Can the brake shaft seal on a 1991 312-8 be replaced without splitting the transmission? Share this post Link to post Share on other sites
ebinmaine 81,282 #2 Posted April 8, 2024 Absolutely Share this post Link to post Share on other sites
WHX?? 58,388 #3 Posted April 8, 2024 (edited) Yep just pick the old one out. Tape the keyway to avoid nicks. Grease & carefully tap the new one in with a piece of pvc 1 1/4 I think? Edited April 8, 2024 by WHX?? 2 Share this post Link to post Share on other sites
Lane Ranger 12,167 #4 Posted April 8, 2024 15 minutes ago, WHX?? said: Yep just pick the old one out. Tape the keyway to avoid nicks. Grease & carefully tap the new one in with a piece of pvc 1 1/4 I think? I also use a very big washer up against the oil seal as you pop the PVC pipe piece with a rubber mallet! 3 Share this post Link to post Share on other sites
ebinmaine 81,282 #5 Posted April 8, 2024 I often file the keyway groove so that's not the tough part for me. The lock ring groove on the outside can be really tough to get a seal past. I think the last time I used HD packing tape to cover the groove. Grease the seal well. Share this post Link to post Share on other sites
JimSraj 593 #6 Posted April 8, 2024 Thanks guys! I’m gonna order one up and get her done. 2 Share this post Link to post Share on other sites
ri702bill 13,396 #7 Posted April 8, 2024 Jim - not totally necessary, but it helps to remove the tire on that side (duh) and raise that side higher than the other so as not to loose fluid..... 1 Share this post Link to post Share on other sites
JimSraj 593 #8 Posted April 8, 2024 Definitely be removing the wheel and that side will be raised up. It’s low on gear oil now so hope not to lose any. Thanks for the reminder though. 2 Share this post Link to post Share on other sites
