fourwheelhorseman 362 #1 Posted April 7, 2024 I was just looking at my fine new tractor reassembling the starter generator and noticed somthing I’ve not ever noticed till now… I’m missing g the points cover as well as the small screws to hold it on! Anyone have an extra that they would let go of? 2 Share this post Link to post Share on other sites
ebinmaine 80,081 #2 Posted April 7, 2024 What's the distance between the bolt holes? Share this post Link to post Share on other sites
squonk 47,733 #3 Posted April 7, 2024 All K series Kohler points covers are the same. I have a cover but no grommet or screws 1 Share this post Link to post Share on other sites
fourwheelhorseman 362 #4 Posted April 7, 2024 I can probably find one locally,the screws are probably going to be the hardest thing to find. I can’t beleive I didn’t see that! Share this post Link to post Share on other sites
ebinmaine 80,081 #5 Posted April 7, 2024 53 minutes ago, fourwheelhorseman said: the screws are probably going to be the hardest thing to find. I'd bet if you borrowed a screw from another Kohler and took it to a good hardware store they'd have a few. Alternatively, I could get you the size and head type and you could get some from K. L. Jack or Bolt Depot or McMaster Carr. Share this post Link to post Share on other sites
ri702bill 12,696 #6 Posted April 7, 2024 New aftermarket cover and seperate gasket available on the "Jungle" site - not exactly cheap. No screws. (Same size screw as the 2 that mount the points...) Look on the wire going to the points - the grommet MAY still be there. 1 Share this post Link to post Share on other sites
Achto 32,252 #7 Posted April 8, 2024 5 hours ago, fourwheelhorseman said: I’m missing g the points cover as well as the small screws to hold it on! Those screws are 10-24 x 3/8". Phillips or Allen head, either one will work. Available at any hardware store. 3 1 Share this post Link to post Share on other sites
WHX?? 57,642 #8 Posted April 8, 2024 5 hours ago, squonk said: All K series Kohler points covers are the same. I have a cover but no grommet or screws There ya go ... grommets on flea bay & Kohler shops. 12 minutes ago, Achto said: Those screws are 10-24 x 3/8". Phillips or Allen head, either one will work. Available at any hardware store. Not that it makes any difference you may have a service motor ther. Horizontal coil mount is a tell tale. Share this post Link to post Share on other sites
JimSraj 583 #9 Posted April 8, 2024 Looking to learn something here. What’s a service motor? Thanks in advance. 1 Share this post Link to post Share on other sites
WHX?? 57,642 #10 Posted April 8, 2024 (edited) A dealer replacement motor Jim. Most likely doesn't have WH specs and different in other aspects but designed to be a "universal" replacement to cover most applications. Often required specific parts from OEM motor for OEM function. Sometimes sold as a "short block" just requiring more parts from motor being replaced. Sheet metal, ignition components, starters etc. Another tell tale is a service motor (Kohlers) are painted in a light gray primer looking color. Sometimes painted OEM color by the dealer. An upcharge customers often declined. Edited April 8, 2024 by WHX?? 1 1 Share this post Link to post Share on other sites
ebinmaine 80,081 #11 Posted April 8, 2024 6 hours ago, JimSraj said: Looking to learn something here. What’s a service motor? Thanks in advance. 5 hours ago, WHX?? said: A dealer replacement motor Jim Appreciate that definition Jim. I've also seen a few black engines. Some refer to them as "Counter Engines". Same basic idea in universality but a Counter engine was built to be sold complete and installed in whatever machine it was needed. Here in Portland Maine there's a Toro dealer and Kohler dealer almost across the street from each other. Both have used them. Lots of car manufacturers do similar. 1 Share this post Link to post Share on other sites
