jeremi3210 759 #1 Posted April 7, 2024 Question guys? Anyone on here have the original top link that came with a d tiller? Looks like a flat peice of steel with two holes in it, the manual says ya need to run this one with the tiller. That is the only part iam missing from mine. If someone has it what is the measurement between the holes? Share this post Link to post Share on other sites
WHX?? 58,302 #2 Posted April 7, 2024 I may hsvev that piece. I been kicking a piece like that around the shop. No idea what it was for. Yah if someone has a pic & dims. 1 1 Share this post Link to post Share on other sites
jeremi3210 759 #3 Posted April 7, 2024 Kick it my way Jim! Or at least the dimensions! It's not a huge deal but makes a difference on how high it lifts. 1 Share this post Link to post Share on other sites
WHX?? 58,302 #4 Posted April 7, 2024 See if i can find it now! Think it went out to the parts shed and a bomb went off in there... 2 Share this post Link to post Share on other sites
jeremi3210 759 #5 Posted April 7, 2024 I understand that!!! Share this post Link to post Share on other sites
WHX?? 58,302 #6 Posted April 7, 2024 It's not this piece is it? Thinking not but never know. It was on Alice the C-120. I have no idea why. I took it off and just extended the lift cable to the plate on top. Much better transport. Share this post Link to post Share on other sites
jeremi3210 759 #7 Posted April 7, 2024 Nope, don't know why that be on that set up unless the po had to shorted the lift cable. Share this post Link to post Share on other sites
Pullstart 71,366 #8 Posted April 8, 2024 Yeah the D is a 3 point system, not cable… right @jeremi3210? 1 Share this post Link to post Share on other sites
jeremi3210 759 #9 Posted April 8, 2024 21 minutes ago, Pullstart said: Yeah the D is a 3 point system, not cable… right @jeremi3210? Yep 3 point lift. The adjustable one works but tye shorter it is the higher the tiller will lift, just don't want to make it to short it will bind up the pto shaft. Share this post Link to post Share on other sites
peter lena 10,089 #10 Posted April 8, 2024 @WHX?? you can also use a garage door lift arm , very similar , in size / shape / purpose , BTW that flat belt idler , is very prone to drag failure , good time to verify it still spins at all , usual , bearing lubricant failure , also like climbing gear lubricants' makes everything work easier , Pete Share this post Link to post Share on other sites
killroy 36 #11 Posted April 10, 2024 On 4/7/2024 at 7:14 PM, WHX?? said: It's not this piece is it? Thinking not but never know. It was on Alice the C-120. I have no idea why. I took it off and just extended the lift cable to the plate on top. Much better transport. Don't want to hijack a thread but any chance of getting dimensions and placement pictures of that lift plate? I've been looking for that for a long time. Can't tell where it's mounted on your tiller. I need to make one for mine . Again sorry for the hijack. Thanks Eric Share this post Link to post Share on other sites
