TJN 18 #1 Posted April 5, 2024 I have a 1973 C120 (1 0460-8) 42" mower, 12hp, automatic. The "pull handle" will move the mower up etc. BUT won't lock into place. PINTA! I've had it apart but don't see a problem. Any suggestions? Many thanks, TJN Share this post Link to post Share on other sites
Lee1977 7,813 #2 Posted April 5, 2024 15 minutes ago, TJN said: I have a 1973 C120 (1 0460-8) 42" mower, 12hp, automatic. The "pull handle" will move the mower up etc. BUT won't lock into place. PINTA! I've had it apart but don't see a problem. Any suggestions? Many thanks, TJN If the lift rod is adjusted too short will cause it not to latch up. 3 Share this post Link to post Share on other sites
TJN 18 #3 Posted April 5, 2024 Lee, thanks for the info! I'll try to adjust in the AM! Thanks again. TJN Share this post Link to post Share on other sites
Ed Kennell 47,952 #4 Posted April 5, 2024 Is deck attached to the attach-o-matic correctly? The notch in the deck support rod must be hooked on the larger rod on the tractor. Share this post Link to post Share on other sites
