Coors 0 #1 Posted August 26, 2009 I found a deck and snow plow for sale that came off of a 314-8. Will these fit my 520H? I tried to look them up but the numbers the guy gave me do not show up on toro.com. The numbers are not the clearest. The blade is 06488C01 or 0648BC01 followed by 39366. The manufacture date is faded. On the mower deck, the I.D. is 0542MS05 72994. Can anyone help me out? The deck is believed to be a 42", but I wasn't sure if a 42" work on a 520H with a 60" deck. I know the plow will need an "completing kit". Thanks. Share this post Link to post Share on other sites
Duvall 0 #2 Posted August 26, 2009 I am far from a tractor head. I can tell you that the 300, 400 and 500 series used the same attachments. I use a 42" rear discharge and a 48" side on my 520, and I also have the 60" deck. Share this post Link to post Share on other sites
whfan74 2,074 #3 Posted August 26, 2009 It will fit as long as you don't have the forward swept axle........that does cause problems for a blade. If you don't have an swept axle then you can only handle up to a 48" mower deck. What year is your tractor? That will help us better answer your question. Share this post Link to post Share on other sites
Coors 0 #4 Posted August 26, 2009 It will fit as long as you don't have the forward swept axle........that does cause problems for a blade. If you don't have an swept axle then you can only handle up to a 48" mower deck. What year is your tractor? That will help us better answer your question. My tractor is a 1995 520H with swept front axles. Currently I have a 60in deck. I didn't know if I could scale down to a 42 w/o problems. From reading older post I see that I will need a completing kit for the snow plow in order to move the plow away from the front swept axle/tires. Is the correct? Can I make this work with an extension? Thanks, Share this post Link to post Share on other sites
whfan74 2,074 #5 Posted August 26, 2009 Since you have the forward swept axle you won't have any problems with the mowing deck. You are right, you will not only need the extension for the blade but you will also need a different angling arm. The ones for the 520 swept axle have a bend to them so they can be accessed by the driver. Without the proper handle the arm would be up too far to make it work and will interfere with the tractor itself. A few have fabbed up there own extension kits. I have personally found one for another member that was a NOS item. It wasn't cheap, but it was correct. Share this post Link to post Share on other sites
Jim_M 179 #6 Posted August 26, 2009 The completing kit also relocates the lift point on the plow frame. Share this post Link to post Share on other sites
jusjeepn 59 #7 Posted August 26, 2009 Couldn't find any for sale when I needed them, so I made them! These are a made a lot heavier than the factory ones. They work perfectly but you also have to add a piece to the front to prevent sway! My extension was made one inch longer than the factory setup to accommodate my custom 60" blade. This is it pushing gravel. Works great! Share this post Link to post Share on other sites
whfan74 2,074 #8 Posted August 26, 2009 Yes sorry about that Jim is exactly right on that! Pat.........nice fab job! Love seeing those working pictures! Share this post Link to post Share on other sites
