Rob R
520H bogging down and stalling engine
Ed Kennell
11 minutes ago, Blasterdad said:
:text-yeahthat:Me too....:popcorn:
X3
nylyon
Just fixed it, try now guys
nylyon
Wow Rob, that was certainly some carnage, wonder what would cause the rod to shatter like that?  Sounds great now though and you have one of the awesome 520’s!
kpinnc
4 hours ago, Rob R said:
As promised here she is running PROUD!
Sounds great!
There are plenty of mods to keep that rear cylinder cool. I would say with a P220, looking into them is a good idea before mowing season.
Some folks put a vent in the belt guard. I cut mine out altogether. I also put a "peep hole" over the rear cylinder that let me ensure no grass clippings clogged the cooling fins. Probably a bit of overkill, but that is normal for me.
Regardless, I'm glad it all worked out. You saved another Wheel Horse! :thumbs:
  • Excellent 3
Lee1977
I just cut the belt guard off on my 520 -H isn't need on a hydro. I'm old enough to keep my fingers out of it.
  • Excellent 1
Rob R
HI Fellow wheelers thought I would do an update on the 520H. I have conquered all the common electric issues mostly by ripping out the light plastic fuse box and replacing it with protected heavy duty in line fuse holders so now all the gages work, and it charges like a champ. The engine starts beautifully and runs great, the deck is refurbished and also cuts well. I vented the belt guard, so it is cooling the back cylinder.
So the only remaining issue is that when it gets really hot and I am putting the "onions" to it i.e. going up a steep hill it will puff some smoke (not white). I did a compression check on both cylinders yesterday and was surprised with the results 120 on the front and 122 on the back (cylinder I replaced the connecting rod on) so compression and rings should not be a problem same with head gasket(s).  So I am wondering if the valve seals are shot and causing the issue???  Are these relatively easy to replace, what disassembly and special tools are required. Do you have any other ideas..... Thanks men  p.s. i cut slots in the belt guard to help with back cylinder ventilation and it works well.
Edited by Rob R
lynnmor
Only the intake valves have seals.  You likely are due for a valve adjustment anyway so getting to the seals is just some more work.  You will need to remove the exhaust, intake and valve covers for adjustment.  To get to the seals the valve springs need to be compressed and removed.  Depending on the type of valve spring compressor used the heads may need to come off.
Bill D
Any chance it's running rich?  White smoke would be oil burning, black smoke sounds like it's running rich.  How do the plugs look?
Rob R
22 hours ago, Bill D said:
Any chance it's running rich   White smoke would be oil burning, black smoke sounds like it's running rich.  How do the plugs look?
It might well be running a bit rich Bill, but my understanding is the carb in NON-adjustable. I have not monkied with since it starts real easy, runs smoothly and idles nicely so.... really didn't want to mess with it unless I know what to do.
I did pull the plugs to do the compression chk they did have some carbon on the rims, again I was truly shocked with the value(s) 120 PSI and 122 PSI respectfully, so I cleaned them and screwed them back-in.
953 nut
If an engine idles well, but runs erratically when revved up, like it hits and misses, pops and backfires, then chances are, it needs a new condenser/capacitor. And always install a condenser/capacitor with the wire facing downward so rain water and/or when washing off engine, water will not enter inside condenser/capacitor, ruining it. With water inside the condenser, this will also allow it to idle well, but cause it to run erratically when revved up.
Bill D
On the Onan "P" series the condenser is connected to the positive terminal.  This controls voltage spikes that could damage the ignition module or cause misfires.
953 nut
Does that mean it couldn't possibly be the problem and should be totally ruled out?
Edited by 953 nut
fat finger
Rob R
The engine runs well no missing, popping or backfires the issue is that when under heavy load (mowing with a 48" mower and going up a steep incline she blows a considerable amount of smoke all the while running just fine.
  • Confused 1
953 nut
So it isn't BOGGING DOWN and STALLING as in the thread's title?
lynnmor
Are you using exactly 2 quarts of SAE 30 oil and the correct oil filter?  I use Fleetguard PF3339 or Onan 122-0800 filters and Kohler HD30 oil.  Is the air filter new with a clean pre-filter?  It the breather clean and assembled correctly?
Rob R
Correct that was the original problem which was the broken connecting Rod it ran surprisingly well stumped me completely at the beginning but I found it quickly as it had no power.  Page 1 has all that detail and a video of the engine running with the new conn rod.
Edited by Rob R
Rob R
Yes excepting the engine oil I used a multi-grade oil it is due for a change so I can definitely go to the Sae 30 weight to be honest was thinking about going to a 40 weight
lynnmor
I wouldn't do 40 unless the engine is spent.  !0w-30 is OK for cold temperatures or light usage.
Rob R
Okay the thing that has me stumped is that since the conn rod change it runs great and I have 120PSI on the cylinder one and 122PSI on the cylinder two with the new rod....so engine is definitely not spent, that's why I was thinking the oil is getting into the cylinders perhaps thru the valve seals..... but then I thought again when I start it little of no smoke so kinda crossed that one off......
lynnmor
You could have good compression with worn oil rings.  I have an Onan torn down right now that had good compression and found one oil ring with about 3/8” missing from the end, no clue where it got to.  I tore it down because of rod noise and there was excessive clearance in the crank end.  When we buy used engines it is impossible to know the extent of the abuse, many don’t take care of oil changes or air filters.  These engines get dusted easily since they work in harsh environment.
  • Similar Content
    • Truckedup1
      By Truckedup1
      I have a very recently restored 1989 wheel horse 520-HC tractor with 60” deck. Family owned for over 10 years but now it’s time for another project. Please contact me with any questions I have the original 60” deck but it was rough so I sourced the current deck off this site, it really is in excellent condition for not being restored.
    • jleitschaft
      By jleitschaft
      Hello All,
            New to the group and looking for advice. My father was a devoted wheel horse enthusiast for many years. He only cut grass with a wheel horse tractor (rear discharge deck) pulling a Parker lawn sweeper. We have a lot of property and it took him a while but he was retired and loved being on the wheel horse. When he got sick, I had to take over all the lawn maintenance. All of our family lives close on the same road. At the time, I was responsible for maintaining 7 properties plus my fulltime job. Using the wheel horse was not an option for me so I bought a commercial zero turn mower.  Unfortunately, in 2017 my father passed away. I have all his tractors and it has been hard for me to think about what to do with them. He had 6 wheel horse tractors total. 3 tractors we used for cutting grass and 3 tractors are show pieces that have never cut a blade of grass. I have a few guys that have been asking me for years to sell them but I am not sure if I’m ready. I am turning to the group because I am lost at what I even have. Its my belief that the tractors are rare and the conditions are mint. If anyone would be willing to express their opinion and provide feedback I would be grateful.
      Wheel horse 420 LSE (shows 7.5 hr)
      Wheel horse 520 hydro (shows 92 hr)
      Wheel horse classic GT (shows 26 hr)
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
    • Workin_Horses
      By Workin_Horses
      Nice solid clean 60" deck for 520H Model # C560SC04       $500 OBO
    • RJ Hamner
      By RJ Hamner
      Has anyone found a good source for gold plated (not the thin plated stuff) male/female connectors?
      And/or weather proof connector housings?
       I’m still not sure if this was under engineered, or they didn’t think the product would last this long (couldn’t envision the Wheel Horse Collector's Club)
      Asking for me and a friend
