ebinmaine 80,656 #1 Posted March 27, 2024 We got a small bin o stuff with the C121 Automatic from @PWL216 These things are not familiar to me or Trina. Whut they be?? 1 Share this post Link to post Share on other sites
c-series don 12,421 #2 Posted March 27, 2024 I’ve no clue Eric, never seen that stuff before. 1 1 Share this post Link to post Share on other sites
ebinmaine 80,656 #3 Posted March 27, 2024 3 minutes ago, c-series don said: I’ve no clue Eric, never seen that stuff before. Thanks Don. We're the most concerned about the broken thing. We don't have the other half. 1 Share this post Link to post Share on other sites
JoeM 10,253 #4 Posted March 27, 2024 the pin looks like the one used to connect the lift cylinder to the rock-shaft on a hydro. 5 Share this post Link to post Share on other sites
ebinmaine 80,656 #5 Posted March 27, 2024 5 minutes ago, JoeM said: the pin looks like the one used to connect the lift cylinder to the rock-shaft on a hydro. Would it be used on a manual lift too? 1 Share this post Link to post Share on other sites
JoeM 10,253 #6 Posted March 27, 2024 4 minutes ago, ebinmaine said: Would it be used on a manual lift too? Not that I know of. The handle is attached directly to the rock-shaft. You might have got some overflow parts. I have had that happen when folks sell me a machine and throw in the kitchen sink. 3 Share this post Link to post Share on other sites
ebinmaine 80,656 #7 Posted March 27, 2024 2 minutes ago, JoeM said: Not that I know of. The handle is attached directly to the rock-shaft. You might have got some overflow parts. I have had that happen when folks sell me a machine and throw in the kitchen sink. Haven't found the sink..... yet..... 1 Share this post Link to post Share on other sites
Pullstart 71,218 #8 Posted March 27, 2024 The blocks, do they fit a plow bracket bolt pattern? Could have been massive drop brackets for more front lift? 1 Share this post Link to post Share on other sites
ebinmaine 80,656 #9 Posted March 27, 2024 3 minutes ago, Pullstart said: The blocks, do they fit a plow bracket bolt pattern? Could have been massive drop brackets for more front lift? That's what we thought at first but there's nowhere near enough space between the holes Share this post Link to post Share on other sites
PWL216 1,278 #10 Posted March 27, 2024 @ebinmaine Hi Eric. I would disregard those parts. They were probably some parts on the bench that wound up in the box somehow. I don’t recall them coming off of the 121. 1 Share this post Link to post Share on other sites
ebinmaine 80,656 #11 Posted March 27, 2024 5 minutes ago, PWL216 said: @ebinmaine Hi Eric. I would disregard those parts. They were probably some parts on the bench that wound up in the box somehow. I don’t recall them coming off of the 121. I was kind of hoping you'd say something like that. BBT and I have only been into a select few of this body style and neither one of us could figure out what these were or where they went. Spare parts box, it is! Share this post Link to post Share on other sites
Lee1977 7,764 #12 Posted March 27, 2024 (edited) That half looks like a broken wheel bushing, My tub trailer had bushings. Never seen one broken, I hammered them back in worn wheels with some shim stock for use on my wagon, and they didn't break. Must be some of that junk used on other brand Lawn Tractors. Edited March 27, 2024 by Lee1977 2 Share this post Link to post Share on other sites
wallfish 20,576 #13 Posted March 27, 2024 (edited) It's a broken wheel bearing/bushing Blocks look like homemade spacers or something. Could they fit under the seat pan for something like that 416-8 to raise it for larger tires? Hole spacing the same? Edited March 27, 2024 by wallfish 1 1 Share this post Link to post Share on other sites
ebinmaine 80,656 #14 Posted March 27, 2024 4 hours ago, wallfish said: It's a broken wheel bearing/bushing Blocks look like homemade spacers or something. Could they fit under the seat pan for something like that 416-8 to raise it for larger tires? Hole spacing the same? Valid question. We can take a look at that next time we're messing with this tractor. Share this post Link to post Share on other sites
Lee1977 7,764 #15 Posted March 28, 2024 I made up some to put under the seat hinge, the seat back was too vertical . 1 Share this post Link to post Share on other sites
ebinmaine 80,656 #16 Posted March 28, 2024 4 minutes ago, Lee1977 said: I made up some to put under the seat hinge, the seat back was too vertical . Understandable. We remove the springs from all our own tractors. This one being for other folks I'll leave the springs but I like that idea. Share this post Link to post Share on other sites
