MSBiker 45 #1 Posted March 14 Does anyone have a good way to remove the crank oil seal on a Tecumseh H60 so you can get at the clip and take the side cover off. I have a new seal on order so destroying the oil seal is not the issue. I just can't figure a good way to get it to slide off. Personally it seems kinda backwards. Oil seal then clip? Seems like it should be other way around. Thanks for the help. Share this post Link to post Share on other sites
