peter lena 8,125 #1 Posted February 28 so simple and easy to , start a movement functional ease , , very often see rusty connections that are , SAPOSED TO MOVE . weather its a clutch pedal mount end , with oil hole in mount point ! or typically a connection cable thats long frozen in place . found this very effective , to anything rusty , even tried it on a cloudy paint area , spread some on , lightly rub it in , let it sit wet for a day , rub it down till dry , might even break thru the , long neglected paint , just a suggestion , both ends of a choke / throttle cable , related linkage , pete https://www.homedepot.com/p/3-IN-ONE-4-oz-Fast-Acting-Penetrant-Drip-Oil-120015/300719551?source=shoppingads&locale=en-US&pla&mtc=SHOPPING-BF-CDP-GGL-D25S-025_031_GARAGE_AUTO-NA-Multi-NA- 2 1 Share this post Link to post Share on other sites
peter lena 8,125 #2 Posted February 28 @Treepep , @Maxwell-8 , if you get that , another related , YOU CAN,T DO THAT , area for a test is in / on a car body seam , like in a tailgate , lower seam or trunk lid lower seam . couple days later , the seam will have an oil slick in it . this is very good stuff to try that with , put some similar in my car doors , lighter penetrating oil , is the creeper you want , the verification of creep , is the carrier you want for a heavier gear oil aerosol , try it also under your hood , for seam penetration . go oily , Pete 1 Share this post Link to post Share on other sites
953 nut 52,133 #3 Posted February 29 I have used 3-in-One for years, good stuff. I will get some of their penetrating oil too. 2 Share this post Link to post Share on other sites
c-series don 7,893 #4 Posted February 29 I too have been using 3-n-1 oil since I was a kid. My dad always had it on hand. One of the things I like best about it is that sometimes you just need a little drop of oil. I don’t need a spray can of something that too much is going to come out of, I just need a drop or two of oil period that’s all. Like an interior door hinge for example, just a drop or two, nothing to make a mess! In fact I saved my old metal cans because I thought they were cool and would someday be made of plastic. Well wouldn’t you know! Yup, plastic now! 1 Share this post Link to post Share on other sites
peter lena 8,125 #5 Posted February 29 @c-series don this the visual proof you want with a creeping penetrant oil , every time I see anything relatively new , thats rusted out , its just a basic follow up , to the issue , Napa , macs , chain / cable lube is good , and the price is also good . another thing , if you are spraying into a closed area with a top of area access , thats what you want , for top to bottom spread of lubricant , make sense ? look at any pick up tailgate , rotted out , so simple to stop that , cab doorway seaming , same thing , door trim removal , or screw removal , gives you a spray can tube or small bottle , squirt opportunity . looking right at it , Pete Share this post Link to post Share on other sites
