kpinnc 10,980 #26 Posted February 29 I can't top the chicken plucker, but almost everything I have is saddled with homemade attachments. Not to mention none of my machines are not modified in some way. Most would be more accurately described as "Frankenstein" if I'm being honest. One has the crane attached. One has a 3 point hitch. Several are repowered. The only factory implement I have is a couple decks and a tiller. I even have a modified Exmark deck on a tractor. Built my FIL a leaf vacuum for his Charger. Point being, one common theme in this thread is that you can make most anything work on these tractors! 1 9 Share this post Link to post Share on other sites
Tractorhead 8,658 #27 Posted February 29 First a Aluminum FEL - for a 212 - ok that was my first machine - that addicted me not a real Wheelhorse but i got it 1,5 Years later - however it works and can be adapted if needed. One and a half year later i got me an 656 as a “ daily driver“.. For lot‘s of Fun i built me few Thingis to simplify my Work... I love my broom each Autumn simply and reliable can be used with my selfmade Plowframe The Selfmade garden Cart - made out of an collapsed Pavillon doesn‘t look that stable but it can easy take a load up to 200 Kilos (allready tested) because here wheelhorse parts be ultrarare i made me few myself like the Snowplow including Frame enlarged Tiller with improved Engine 6 HP and enlarged to 90cm workwidth selfmade Adapter for original Wheelhorse rear lift insert. The next Attachement was a Double side Tilt plow Can be arrested in 5 different steps modified Pulley driveshaft with zerk fitting and many more... 1 9 Share this post Link to post Share on other sites
Ed Kennell 36,022 #28 Posted February 29 2 hours ago, kpinnc said: described as "Frankenstein" if I'm being honest. No way, I'd call it "Einstein". 4 1 1 Share this post Link to post Share on other sites
kpinnc 10,980 #29 Posted February 29 1 minute ago, Ed Kennell said: No way, I'd call it "Einstein". Now that is a first, for anything associated with me! Greatly appreciated! 2 1 2 Share this post Link to post Share on other sites
Tractorhead 8,658 #30 Posted February 29 (edited) Comeing project is in the upper of the top Pict. In the upper Pic you also can see my Jackshaft on the Horse... Needed for my „Sucidal Disc Mower“...😎 no Molehole or bushes or even small Stumps will destroy this mowerblades it flatenes all out. but take care on your feet... 🤫😁 Extremely dangerous but also effective. Edited February 29 by Tractorhead 6 1 Share this post Link to post Share on other sites
squonk 39,110 #31 Posted February 29 (edited) Sorry for the bad pics. Allis Chalmers mid grader blade converted to a back blade Converts to a mid grader. My Economy Power King with a loader built here from Economy drawings (Bucket is different design) home made front weight bracket and barbell frt. wheel weights Converted this planet Jr. disc to a mid disc Edited February 29 by squonk 2 8 Share this post Link to post Share on other sites
Ed Kennell 36,022 #32 Posted February 29 2 minutes ago, squonk said: mid disc Hey, that disc looks familiar. 1 Share this post Link to post Share on other sites
Lee1977 6,283 #33 Posted March 1 (edited) Edited March 1 by Lee1977 1 8 Share this post Link to post Share on other sites
Lee1977 6,283 #34 Posted March 3 (edited) Built this out of some left over steel the beam is too short, need to be minum of 8" longer but it works. Easy to get out of the trench, just back up. Have a cord attached to pull it back up, that thing jurks hard broke the cord a few times when it caught on something you don't want to be holding that cord when backing up. It might work better with the 16" adjustable clevis hitch I built. Edited March 4 by Lee1977 9 2 Share this post Link to post Share on other sites
Sailman 1,135 #35 Posted March 4 Built this "Garden Bucket" for my GT 14. Not a true FEL but much easier than shovel and wheelbarrow! Used linear actuator and ATV bucket. Built rear weight box from galvanized electric supply box and can add 12 volt marine deep cycle battery in weight box to run the bucket. 6 5 Share this post Link to post Share on other sites
Lee1977 6,283 #36 Posted March 31 (edited) Edited March 31 by Lee1977 7 Share this post Link to post Share on other sites
87 416-8 horse 284 #37 Posted March 31 48 minutes ago, Lee1977 said: That makes taking the trash out fun! 1 Share this post Link to post Share on other sites
