loudtractor 50 #1 Posted February 20, 2024 Looking for a snowblower to fit a c120, not sure exactly which part number I'm looking for. I'm in SW Michigan, South of Kalamazoo 35 miles. I could drive 100 or so miles for a decent one. Thanks for looking, Matt Share this post Link to post Share on other sites
Ed Kennell 46,477 #2 Posted February 20, 2024 to the This should be posted in our classified wanted section. May be a Mod will move it for you. Share this post Link to post Share on other sites
loudtractor 50 #3 Posted February 20, 2024 OOPS! sorry, I thought that was where I had it! Still learning to navigate the site. Appreciate any help. 3 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,326 #4 Posted February 21, 2024 Single stage options Front quick hitch introduced in 1973. Snowthrower rear frame has a 5/8" diameter round bar. 1973-74 model 6-6212 plus 6-9113 1974 model 6-6213 - (First model to include 8-0221 extensions without the front straight return - just a flat plate) 1975 model 6-6214 - (First model to include 8-0221 [103552 replaced by 93-1617 and 93-1617-01] side extensions with the front straight return. First model to have a cable spool on chute rotating crank) Chute crank support decal 104461. 1976 model 6-6215 ------ Chute crank support decal 104461. This one - 1976 model 66-42ST01 - Chute crank support decal 104461. and this one are likely identical. The model number format changed. 1977 model 76-42ST01 - Chute crank support decal 104461. This one 1978 model 86-42ST01 - Chute crank support decal 104461. and this one 1979 model 96-42ST01 - Chute crank support decal 104461. and this one may be all the same. They started using a different model number for each model year. 1980 model 06-42ST01 - (Last 42" model to use 4 grooved rollers for the chute) 1981-82 model 06-42ST02 - (First model to use plastic collar for the chute but was a retrofit for older models. Last model to use wheels) 1983 model 06-42ST03 - (First model to use skids) 1984-87 model 06-42ST04 - (Last model to use a 3/4" diameter driveshaft) 1987-89 model 06-42ST05 - (First model to use a 7/8" diameter driveshaft) 1990 model 06-42ST06 - (Last model to use a cable to turn the chute) 1991-93 model 06-42ST07 - (First model with tall chute retained by 3 individual grooved retainers) 1993-2001 model 79360 - (2001 and earlier will fit 2002-2007 with kit 105-1503) (1994 first year for replaceable blower housing scraper bar) 2002-2007 model 79362 1 Share this post Link to post Share on other sites
loudtractor 50 #5 Posted February 21, 2024 Thanks! Exactly what I was looking for. I have one here with no ID or stickers. It has , or is supposed to have, a control rod next to the chute control. Am I correct in thinking this is for an older short frame? It has wheels, and holes for side angle plates, 32" I think. I'll put a picture up later today Thanks Matt Share this post Link to post Share on other sites
loudtractor 50 #6 Posted February 21, 2024 Here's a picture, any help with id or which tractor it fits would be awesome. Thanks! Matt Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,326 #7 Posted February 21, 2024 Here is a list of the 32" models. The first 42" list is better suited to your tractor. 32" Snowthrower DNA - For tractors with horizontal shaft engines 1963 model ST-323 - Fits 701, 502, 552, 702, 603, 653, 753, 604 (Drive belt 1589 1/2" x 56.5") (Chute turned by belt 1590 3/8" x 43") 1964 model ST-324 - Fits 701, 502, 552, 702, 603, 633, 653, 753, 604, 654, 704, 854, 605, 655, 855 (Uses # 41 chain Pitch 1/2" and roller width 1/4") (Drive belt 1589 1/2" x 56.5") (First model to use cable on the chute) 1965 model ST-325 - Fits 701, 502, 552, 702, 603, 633, 653, 753, 604, 654, 704, 854, 605, 655, 855, 1045, 1055 (Uses # 41 chain Pitch 1/2" and roller width 1/4") (Drive belt 1589 1/2" x 56.5") 1966-1967 model ST-326 - Fits 701, 502, 552, 702, 603, 633, 653, 753, 604, 654, 704, 854, 605, 655, 855, 1045, 1055, 606, 656, 856, 876, 607, 657, 857, 867, 877 (Uses # 41 chain Pitch 1/2" and roller width 1/4") (Drive belt 1589 1/2" x 56.5") 1968-1969 model 6-2211 - Fits 500 Special, Commando 6, Commando 8, WorkHorse 700 (Formerly ST-326) (Uses # 41 chain Pitch 1/2" and roller width 1/4") (Drive belt 1589 1/2" x 56.5") 1971 model 6-0100 - Fits 800 Automatic, 800 Special, Bronco 14, Charger 12, Raider 10, Raider 12, WorkHorse 800 (No record of 6-0100 at Toro. Suspect it was same as 6-0200 plus 6-9112 in one package) (Uses # 40 chain Pitch 1/2" and roller width 5/16") (Uses #101460 lift tube and #9750 5/8" x 69" belt) 1972 model 6-0200 plus 6-9112 - Fits Commando 800 (Uses # 40 chain Pitch 1/2" and roller width 5/16") (Uses #102729 lift tube and #102743 5/8" x 65.95" belt) 1972 model 6-0200 plus 6-9112 - Fits 800 Automatic, Bronco 14, Charger 10, Charger 12, Raider 8, Raider 10, Raider 12, Raider 14 (Uses # 40 chain Pitch 1/2" and roller width 5/16") (Uses #101460 lift tube and #9750 5/8" x 69" belt) 1973 model 6-0200 plus 6-9131 - Fits 8hp 4-Speed (Uses # 40 chain Pitch 1/2" and roller width 5/16") (Use #102729 lift tube and #102743 5/8" x 65.95" belt) 1 Share this post Link to post Share on other sites
loudtractor 50 #8 Posted February 21, 2024 That's a great list! I do have a freshly restored 856. It looks like it might fit this one. I'm going to keep looking for one to fit the C120, now that I have a better idea what to look for.. Thanks! Matt Share this post Link to post Share on other sites
Pullstart 70,447 #9 Posted February 21, 2024 I see a beach ball @WHX??. Is that a 6x6 in the background? 1 Share this post Link to post Share on other sites
loudtractor 50 #10 Posted February 21, 2024 Yes sir. 1968 Amphicat. Restoration almost complete. Share this post Link to post Share on other sites
WHX?? 57,280 #11 Posted February 21, 2024 7 minutes ago, loudtractor said: Yes sir. 1968 Amphicat. Restoration almost complete. I was gonna say Argo but Ampicat works for me! I got two snowblowers here that you can have. Rather see them go to use rather than rusting away. One was on a 520 so thinking it would fit a C120. Enough parts to get one out of two for sure. Get some pics later. I'm sure between plow days and shows we could get them over. Share this post Link to post Share on other sites
loudtractor 50 #12 Posted February 21, 2024 Sounds great! I'll look forward to it. Spring is almost here! Share this post Link to post Share on other sites
