Jason Miller 24 #1 Posted February 20, 2024 Put a new carb (refurb) on my 861 the other carb was corroded and totally shot. Now i cant get it to fire. The old one was dumping fuel into engine. I ordered a new plug the old one was swimming in gas. Hopefully this will work. Any suggestions? Share this post Link to post Share on other sites
ri702bill 12,230 #2 Posted February 20, 2024 YES! Do check the oil level and see if it is overfilled with gasoline diluted oil - before you try to start it. An IMMEDIATE oil change may be in order. Bill 1 4 Share this post Link to post Share on other sites
Jason Miller 24 #3 Posted February 20, 2024 I'll change oil. Thanks. I'll keep you posted on it starting. Trying to avoid taking it somewhere. Jason 1 Share this post Link to post Share on other sites
953 nut 66,551 #4 Posted February 20, 2024 The Kohler service manual has a lot of good information in it including carb adjustments. The problem could be a lack of spark, check that first. 1 2 Share this post Link to post Share on other sites
wallfish 20,031 #5 Posted February 20, 2024 What is a 861 ? And what engine model is this? Did it run before the carb swap? Is the ignition actually working? The more accurate information you can provide the better, otherwise the only answers or suggestions you can receive are simple guesses. On a horizontal Kohler, the carb will not dump fuel into the crank case, it will spill out of the front. If you have fuel in the crankcase of one then it's most likely the fuel pump diaphragm is damaged. Which could also explain the non start. Or, when you say "dumping fuel into the engine" does this mean flooding the combustion chamber? Since you mention the plug is wet. 2 4 Share this post Link to post Share on other sites
Jason Miller 24 #6 Posted February 20, 2024 Sorry mistyped. It's a 856 wheelhorse. Fuel was coming out front of carb. Also plug was wet with fuel. Took plug out turned it over to get excess out of chamber still no fire. Took carb to shop for clean they said the internals were corroded. It's a walbro. Got a new carb aftermarket. Tried yesterday have spark but no fire yet plug is wet and black. Waiting on new plug. That's where I'm at. Share this post Link to post Share on other sites
Jason Miller 24 #8 Posted February 20, 2024 Another thing when I took old carb off I lost the piece that connects throttle to carb. Little z wire connector so had to order one if these. Not a good day Share this post Link to post Share on other sites
pfrederi 20,657 #9 Posted February 20, 2024 How are you testing for spark? Share this post Link to post Share on other sites
Jason Miller 24 #10 Posted February 20, 2024 I just left plug on and held it to engine Share this post Link to post Share on other sites
Jason Miller 24 #11 Posted February 20, 2024 I just changed oil it was runny and gas smelling definitely had gas in it. That’s where im at now. 1 Share this post Link to post Share on other sites
wallfish 20,031 #12 Posted February 20, 2024 Have you ever had this engine running before? If you put a spring on the carb you could try starting it. The spring will keep it from reving too high. You could try disconnecting the fuel line to prevent any guessing on flooding and just spay a little carb cleaner or WD 40 directly into the carb to see if she fires off that way Share this post Link to post Share on other sites
pfrederi 20,657 #13 Posted February 20, 2024 Some spark plugs will spark laying on the head but not under compression dry out the plug put it back in spray a bit of carb cleaner (or gas) into the carb and crank. She should pop if not plug is bad or spark is weak.. Share this post Link to post Share on other sites
Jason Miller 24 #14 Posted February 20, 2024 Yes it’s been running like a champ for about the past 8 months. My dad moved it and when he did he kept stalling it out and was flooding it. I had it started for a few minutes but he really had it messed up. The fuel was running out the front of carb. I cleaned everything the best i could got to the. Point where i took carb off and that’s when i replaced it. Also put new fuel filter on and new fuel lines. I’ll do the carb cleaner try. Should i spray that in the intake? Share this post Link to post Share on other sites
RED-Z06 2,718 #15 Posted February 20, 2024 That filter housing to carb mount seems kinda funky Share this post Link to post Share on other sites
wallfish 20,031 #16 Posted February 21, 2024 2 hours ago, RED-Z06 said: That filter housing to carb mount seems kinda funky Are you referring to this bracket? Share this post Link to post Share on other sites
RED-Z06 2,718 #17 Posted February 21, 2024 Just now, wallfish said: Are you referring to this bracket? No, the weird placement of the housing at the throat, looks like its pitched down and sitting low. Share this post Link to post Share on other sites
Jason Miller 24 #18 Posted February 21, 2024 That’s the old carb same bracket Share this post Link to post Share on other sites
Jason Miller 24 #19 Posted February 22, 2024 Hey guys I drained the oil, put a spring on the carb like you said and put the new plug in. It fired right up! Waiting on the carb link that connects the idle to the throttle cable. 2 questions can I replace the metal gas line and 2 connectors? Looks like from the pump to the carb its a metal gas line about 6 inches? Also when is the wheelhorse show in Ardentsville PA? Can I buy a tractor there? Share this post Link to post Share on other sites
Jason Miller 24 #20 Posted February 22, 2024 This is the fuel line that needs replaced also the 2 nuts that connect it Share this post Link to post Share on other sites
RED-Z06 2,718 #22 Posted February 22, 2024 You would have to get something like steel brake line, a flairing tool, bender, ferrules and nuts. Id ne inclined to try and thread in barbed fittings and use rubber hose and clamps 1 Share this post Link to post Share on other sites
oliver2-44 11,515 #23 Posted February 23, 2024 Why do you want/need to replace that metal line. PS save your old carb and show us pictures of the corrosion. Shop are quick to throw a new part at it due to labor cost. Manny repop carbs are a 50/50 success/fail quality. Share this post Link to post Share on other sites
Jason Miller 24 #24 Posted February 23, 2024 Sure will. I'll definitely keep it regardless. I'm hoping this refurbished carb continues to work good. Share this post Link to post Share on other sites
Jason Miller 24 #25 Posted February 28, 2024 What is the easiest way to put this linkage on? Share this post Link to post Share on other sites
