peter lena 8,131 #1 Posted February 14 https://www.denniskirk.com/moose/plow-blade-skid.p519845.prd/519845.sku?trk_msg=AJU1M0IHBD5KT91F433DKQKU2C&trk_contact=4UPCIPTJ6JEVI02EQULBVPKMPK&trk_sid=G9SCRJQQRJKU53I0HDOP96UO4S&tou&utm_campaign=20240214.Dk.Valentines.Day good addition for any long plowing set up , just a suggestion , pete 1 Share this post Link to post Share on other sites
peter lena 8,131 #2 Posted February 14 @TonyToro seen that set up with a spring tension , follow up , allowing blade to cover irregular areas , also look at similar pick up truck set ups , for ideas , Pete 1 Share this post Link to post Share on other sites
peter lena 8,131 #3 Posted February 25 @ tony Toro , seen a compression spring in the movement slide point , allowing the blade to work / move with irregularity's, once that angular slide point is on, slide installed , you can experiment with spring tension , don, t tell anyone , I told you to try this , stay happy pete Share this post Link to post Share on other sites
