RED-Z06 2,676 #26 Posted February 15, 2024 13 minutes ago, kpinnc said: I've seen what a sandy environment does to mower deck parts. Like the wear on your blades, I've seen them worn completely in two in a single season. Mowing once in a sandy area is cool, because the deck gets sandblasted. More than that just eats them up! I cringe when i slide under a customers mower to do blades and every square inch is grey sandblasted bare steel...and the blade tips have a 6" gap 😂 1 Share this post Link to post Share on other sites
cod 121 #27 Posted February 15, 2024 9 hours ago, RED-Z06 said: It can extend life some. I keep a nice front yard and mainly use my Z mower to mow it, i can go all year and still have paint on the blades. Back yard..its just mowing grass and sand Wow, never realized that sandy ground could be so destructive. Up in Maryland, it's only grass buildup and the deck will be fine if you take care of it. Any chance you could cut the rear lawn that's sandy with a sickle bar or older towed reel mower? Both setups could become a PITA but neither would involve lifting/throwing sand around. Good luck with a unique problem. Share this post Link to post Share on other sites
RED-Z06 2,676 #28 Posted February 15, 2024 7 hours ago, cod said: Wow, never realized that sandy ground could be so destructive. Up in Maryland, it's only grass buildup and the deck will be fine if you take care of it. Any chance you could cut the rear lawn that's sandy with a sickle bar or older towed reel mower? Both setups could become a PITA but neither would involve lifting/throwing sand around. Good luck with a unique problem. A reel mower would work...except for the naturally growing Bahiagrass. Front is easy though, back is sandy.. cant afford to water 3/4 acre back yard. Share this post Link to post Share on other sites
