jdog_kustoms 82 #1 Posted August 23, 2009 does anyone know if i can put a normal deck on my tractor or can i only use the gear drive mower deck from factor that has the big pulley on it and if i can what pulley set up do i need or is there a way to put a mule drive on it thanks in advance for all the advice Share this post Link to post Share on other sites
TT-(Moderator) 1,127 #2 Posted August 23, 2009 Read this post: http://www.wheelhorseforum.com/index.php?showtopic=11422 Share this post Link to post Share on other sites
jdog_kustoms 82 #3 Posted August 24, 2009 what is the idler pulley on the quick attack i see on some older tractors would that work also Share this post Link to post Share on other sites
TT-(Moderator) 1,127 #4 Posted August 24, 2009 I've never personally tried to run the mid-mount tensioner assembly with a newer (Attach-Matic) deck and I don't think that it would even work due to mounting carriage/deck drive belt clearance issues. If you have the correct style deck (1966 to 1972) and all of the tensioner pieces it would work fine. If you're after a reliable and modern mower that you can use regularly and gives a nice cut then you should probably equip your tractor with the newer Attach-Matic hitches (including the front hitch adapter) and use the corresponding deck. Share this post Link to post Share on other sites
jdog_kustoms 82 #5 Posted August 24, 2009 ok cool thanks for your help Share this post Link to post Share on other sites
