Wayne0 1,358 #1 Posted January 20, 2024 I just replaced the lining on my PTO and would like to know the proper way to adjust the engagement. Thanks Share this post Link to post Share on other sites
lynnmor 8,091 #2 Posted January 20, 2024 16 minutes ago, Wayne0 said: I just replaced the lining on my PTO and would like to know the proper way to adjust the engagement. Thanks On what tractor? Most WH tractors have a manual PTO that is adjusted by turning the trunnion just above it. The correct adjustment would be just tight enough that it will not slip, for example a snowblower may need a rather firm adjustment. Share this post Link to post Share on other sites
Wayne0 1,358 #3 Posted January 20, 2024 Manual PTO. Just checking if there was a proper clearance spec between the bell and the lining. I know it's .012 for the brake. Share this post Link to post Share on other sites
lynnmor 8,091 #4 Posted January 20, 2024 48 minutes ago, Wayne0 said: Manual PTO. Just checking if there was a proper clearance spec between the bell and the lining. I know it's .012 for the brake. No, just adjust for a firm push. 2 Share this post Link to post Share on other sites
wallfish 18,630 #5 Posted January 21, 2024 5 hours ago, Wayne0 said: Manual PTO. Just checking if there was a proper clearance spec between the bell and the lining. I know it's .012 for the brake. The lever shouldn't end up hard to push because there's quite a bit of mechanical leverage pushing on that plate. It should feel snug right before it cams over to lock in place. 2 Share this post Link to post Share on other sites
Wayne0 1,358 #6 Posted January 21, 2024 Great, thanks. Share this post Link to post Share on other sites
