peter lena 9,434 #1 Posted January 14, 2024 https://www.denniskirk.com/moose/plow-blade-skid-4501-0702.p519845.prd/519845.sku?trk_msg=2GG29DS3BLDK90FGVFCHODGPTS&trk_contact=4UPCIPTJ6JEVI02EQULBVPKMPK&trk_sid=MHJC6PCEF0KQC9VKF4E5PK9JO8&trk_link=EUB68FJ4DNQ4FA9A5FRUOOBPKK&utm_source=ListrakMarketing&utm_medium=Email&utm_term=View+product+recommended+for+you&utm_campaign=2024014.Shop.By.Ride just got this Dennis kirk , notice , simple add on , Pete 1 Share this post Link to post Share on other sites
ebinmaine 74,446 #2 Posted January 14, 2024 6 minutes ago, peter lena said: simple add on Simple if one can weld. It'd be great if there were a bolt-on option. 1 Share this post Link to post Share on other sites
ri702bill 10,003 #3 Posted January 14, 2024 My 79350 48" plow I bought for the C81 came with two bolt on height adjustable bent metal skid pads. It is my understanding some long frame plows of the mid 1990's did not, but the keyholes were there in the plow blade. I welded a 3/8" pad to the underside of each..... 2 1 Share this post Link to post Share on other sites
peter lena 9,434 #4 Posted January 14, 2024 @ebinmaine https://www.homedepot.com/p/The-Plumber-s-Choice-Heavy-Duty-Shelf-Bracket-with-3-8-in-Hole-MAX-LOAD-250-lbs-L-Corner-Brace-for-Plumbing-and-Decor-Iron-38CABG/309987069?source=shoppingads&locale=en-US&srsltid=AfmBOoqY-KNQMm2yQhZScLRYHzQEKGY1hmIctXeAnQIOdUYvJq9YRrsVBqA#overlay this is the type you want , shop around for pricing / size , absolutely bombproof , have a number of these , they will not fail , forget a regular bracket , these are 3/16 + thick , also have some magnetized , so they stay in place for set up ideas . figured you would , think about the opportunity , Pete 2 1 Share this post Link to post Share on other sites
8ntruck 8,136 #5 Posted January 15, 2024 Those are a whole lot cheaper than the Toro bent steel strip skids that are still available. 2 Share this post Link to post Share on other sites
ri702bill 10,003 #6 Posted January 15, 2024 6 hours ago, 8ntruck said: Those are a whole lot cheaper than the Toro bent steel strip skids that are still available. And that is why they have the added wear pads... Share this post Link to post Share on other sites
peter lena 9,434 #7 Posted January 15, 2024 @ebinmaine others related to . PLOW BLADE SKIDS , missing the point , would bolt on the angle brackets , for the mount for , PLOW BLADE SKIDS . that would allow you to fit your skids to your set up . very often use an existing mount , with a different attachment improvement , connection. always look for the OPPORTUNITY to correct a problem , rarely duplicate a failure point . make it better . Pete 1 Share this post Link to post Share on other sites
ebinmaine 74,446 #8 Posted January 21, 2024 On 1/14/2024 at 10:54 AM, peter lena said: @ebinmaine https://www.homedepot.com/p/The-Plumber-s-Choice-Heavy-Duty-Shelf-Bracket-with-3-8-in-Hole-MAX-LOAD-250-lbs-L-Corner-Brace-for-Plumbing-and-Decor-Iron-38CABG/309987069?source=shoppingads&locale=en-US&srsltid=AfmBOoqY-KNQMm2yQhZScLRYHzQEKGY1hmIctXeAnQIOdUYvJq9YRrsVBqA#overlay this is the type you want , shop around for pricing / size , absolutely bombproof , have a number of these , they will not fail , forget a regular bracket , these are 3/16 + thick , also have some magnetized , so they stay in place for set up ideas . figured you would , think about the opportunity , Pete I ordered some of these in 3/8" and 1/2" so I can what will work best for mounting plow sides to make a 48" plow into a big scoop. Share this post Link to post Share on other sites
