cod 136 #1 Posted January 6, 2024 Any consensus on a replacement edge for a snow plow? Hot roll, cold roll, 1/4", 3/8" thickness? Mine is getting worn and I believe it has already been flipped over. Another consideration would be to use rather heavy rubber mud flap, although I suspect it would wear out quickly. Any suggestions would be appreciated or a link to previous posts about this subject. Thanks! Share this post Link to post Share on other sites
grinchsr 674 #2 Posted January 6, 2024 I trashed the steel one and found the correct size piece of UHMV on the internet. I did have to drill the holes using the old steel one for a template. It has been on my plow for a few years and it is not showing much wear and it is not hurting my new driveway which makes me happy. 2 4 Share this post Link to post Share on other sites
ebinmaine 80,932 #3 Posted January 6, 2024 12 minutes ago, grinchsr said: UHMV Grinchsr raises a very important question I often don't consider. Is your driveway newer asphalt, concrete, or do you NOT want it scratched? A high density plastic would be a great alternative. For steels I'd lean towards a piece of whatever was available to be had and try to find something harder like a skidsteer blade. Those are on the jungle site and other places for reasonable prices. Far as sizing goes I have a pretty wicked tendency towards go big or go home but I have a hydraulic lift doing the work. If I was running a manual lift I'd stay lighter on materials. 4 Share this post Link to post Share on other sites
Chaz54 102 #4 Posted January 6, 2024 1 hour ago, grinchsr said: I trashed the steel one and found the correct size piece of UHMV on the internet. I did have to drill the holes using the old steel one for a template. It has been on my plow for a few years and it is not showing much wear and it is not hurting my new driveway which makes me happy. Don’t you mean UHMW? I bought a piece 1/2” x 4” x 48” lg. from Amazon. I then use the standard metal blade as a clamp plate. I also put golf cart tires on the back so I don’t need chains either. As grinchsr said, now I’m not marking my driveway at all. 2 Share this post Link to post Share on other sites
grinchsr 674 #5 Posted January 6, 2024 Oops it was early good catch. UHMW 1 Share this post Link to post Share on other sites
ri702bill 13,190 #6 Posted January 6, 2024 Me- - old school Hot rolled. Tough as nails, not so much fun to put holes in... Share this post Link to post Share on other sites
JoeM 10,317 #7 Posted January 7, 2024 I used an old piece of conveyor belting for a rubber edge and it is sandwiched between the metal blade edge and plow face. 3/8" stuff. lasts a long time. I actually tried this broom thing one year and it worked pretty good. A friend of mine gave it to me. 1 1 Share this post Link to post Share on other sites
ebinmaine 80,932 #8 Posted January 7, 2024 37 minutes ago, JoeM said: Like that Power Angle. 1 Share this post Link to post Share on other sites
OoPEZoO 618 #9 Posted January 7, 2024 (edited) On 1/6/2024 at 9:05 AM, Chaz54 said: Don’t you mean UHMW? I bought a piece 1/2” x 4” x 48” lg. from Amazon. I then use the standard metal blade as a clamp plate. I like that idea…..looks affordable too. How many seasons have you been using it like that? Just curious about overall durability I had also thought about getting one of the horse mats from my local farm store and cutting strips for the same purpose Edited January 7, 2024 by OoPEZoO Share this post Link to post Share on other sites
Wayne0 1,648 #10 Posted January 7, 2024 10 hours ago, ebinmaine said: Like that Power Angle. Doesn't look like a WH frame. What is it and details on the power angle! I love it! Share this post Link to post Share on other sites
