TonyToro Jr. 2,413 #51 Posted January 8, 2024 I got to play in the snow a bit about 7” of wet heavy snow. used my C-145 with a single stage blower, my 310-8 with my new acquired 48” plow my mom used one of our 3 Toro CCR 3650s and I also used our big Ariens 1332. The C-145 and Ariens and the 3650 were the main part of the show and my 310-8 with the plow was just for cleanup. IMG_1752.MOV IMG_1750.MOV IMG_1749.MOV IMG_1751.MOV 1 1 Share this post Link to post Share on other sites
rjg854 12,967 #52 Posted January 8, 2024 Clean up duty today for both tractors. The plow tractor got what I didn't get with the snowblower yesterday. Pushed the snow and ice to the right side of the driveway and then used the blower to send it out into the field. I think I'm ready for the rain that is coming tomorrow. 3 Share this post Link to post Share on other sites
ebinmaine 78,389 #53 Posted January 8, 2024 59 minutes ago, rjg854 said: Calendar potential there Share this post Link to post Share on other sites
ebinmaine 78,389 #54 Posted January 8, 2024 1 hour ago, rjg854 said: Pushed the snow and ice to the right side of the driveway and then used the blower to send it out into the field. Can you please elaborate on this? The windrow from the plowed snow is soft enough for you to use a snowblower? You do this a lot or only for fluffy snow? Share this post Link to post Share on other sites
rjg854 12,967 #55 Posted January 9, 2024 4 minutes ago, ebinmaine said: Can you please elaborate on this? The windrow from the plowed snow is soft enough for you to use a snowblower? You do this a lot or only for fluffy snow? I plowed up the ice, snow and slush and blew all that out into the field. Pretty much what I do after every snow. As you can see by the pictures there's not a lot of room to let snow pile up before I'd be out of room after a few storms. Another factor is if the wind blows out of the south across that field it drifts the driveway. So the lower I can keep the plowed up edge the drifting isn't as bad. And yes this is my regular routine. The tall shoot will throw it out into the field a good 30-40 feet. This snow was on the wet and heavy side. I kinda thought it would clog up, but it did just fine. When I use the blower I have it set a inch above the stone so I'm not blowing stone, because it will blow stone just as easy as snow. 1 1 Share this post Link to post Share on other sites
