lynnmor 8,914 #26 Posted January 13, 2025 (edited) 5 hours ago, ebinmaine said: That second belt guard for a rototiller? That guard is for a vacuum system. https://www.wheelhorseforum.com/files/file/3030-mower-vacuum-lawn-42in-1980-1984-07-42vx01-tipl-snpdf/ Edited January 13, 2025 by lynnmor 1 Share this post Link to post Share on other sites
midpack 1,147 #27 Posted January 13, 2025 (edited) 6 hours ago, ebinmaine said: If for some crazy reason you ever get that taken apart and decide to sell that belt guard, keep me in mind.... Do you want the attachment for the rear too? I was just up there .. Edited January 13, 2025 by midpack 1 Share this post Link to post Share on other sites
ebinmaine 79,716 #28 Posted January 13, 2025 7 minutes ago, midpack said: Do you want the attachment for the rear too? I was just up there .. Sure. No particular rush or anything. I have a tiller here that is going to end up on one of my manual transmission tractors at some point. Might be a good candidate for the Tecumsehorse because that has the markings of being in possession of that guard already at some point. Share this post Link to post Share on other sites
midpack 1,147 #29 Posted January 13, 2025 Ok, I'll let you know when I bring it up 1 Share this post Link to post Share on other sites
Bill D 2,995 #30 Posted April 29, 2025 On 1/12/2025 at 6:20 PM, midpack said: You can see it here, nothing fancy but it works great 😃 What is that pedal from? Any pictures of the linkage under that belt guard? Thanks. 1 Share this post Link to post Share on other sites
midpack 1,147 #31 Posted April 29, 2025 Pedal is off a 269(?) Wheel Horse. I had to run a 3/4" drill through the mount diameter IIRC. I can get a picture later. I'm in Maine right now but the tractor is in MA Share this post Link to post Share on other sites
Bill D 2,995 #32 Posted April 29, 2025 7 hours ago, midpack said: Pedal is off a 269(?) Wheel Horse. I had to run a 3/4" drill through the mount diameter IIRC. I can get a picture later. I'm in Maine right now but the tractor is in MA Thanks, much appreciated. Share this post Link to post Share on other sites
midpack 1,147 #33 Posted April 29, 2025 It's a little dirty but I've been using for around 5 years with the only adjustment being the back spring tension. I used a plate mounted to the rod attaching hole. It moves the drive lever front and back. The block on the lever was something I made when I was working Share this post Link to post Share on other sites
Bill D 2,995 #34 Posted April 29, 2025 3 minutes ago, midpack said: It's a little dirty but I've been using for around 5 years with the only adjustment being the back spring tension. I used a plate mounted to the rod attaching hole. It moves the drive lever front and back. The block on the lever was something I made when I was working I like that. I may have to buy one and try it. I'm always looking for hydro pedal ideas. Share this post Link to post Share on other sites
