Just getting started 22 #1 Posted December 18, 2023 I have been out of the engine overhaul business now for probably 40 years. Now I have a couple to overhaul and parts to wash. My problem is when I started looking for a parts washer all I can find are ones that are for water based solvent (soap). What do you guys use now days, are you stuck with this stuff? Does this leave a film on your internal parts that is not the best to mix with the oil in a freshly overhauled engine? What do you do to deal with this ? Thanks. 1 Share this post Link to post Share on other sites
Achto 31,469 #2 Posted December 18, 2023 40 minutes ago, Just getting started said: What do you do to deal with this ? I have one of these. I use mineral spirits in mine with no issues. Been in use for at least 4yrs now. https://www.harborfreight.com/20-gallon-parts-washer-with-high-flow-pump-58679.html 6 Share this post Link to post Share on other sites
pfrederi 20,183 #3 Posted December 18, 2023 I have had one of these cheap washers for many years I use the SC gunk and kerosene 3 Share this post Link to post Share on other sites
Just getting started 22 #4 Posted December 18, 2023 8 minutes ago, Achto said: I have one of these. I use mineral spirits in mine with no issues. Been in use for at least 4yrs now. https://www.harborfreight.com/20-gallon-parts-washer-with-high-flow-pump-58679.html That is good news, I like using mineral spirits for cleaning a lot of things. And it's fairly reasonable. Thanks. 4 Share this post Link to post Share on other sites
Streetrodchev 1,079 #5 Posted December 18, 2023 I also use mineral spirits 3 Share this post Link to post Share on other sites
rick 284 #6 Posted December 18, 2023 I use the same thing I did in 1968 when I started in auto mechanics- A galvanized foot tub in a welded stand filled with mineral spirits, We used Varsol in the bucket back in the day. 3 Share this post Link to post Share on other sites
953 nut 65,026 #7 Posted December 19, 2023 I have the same HF parts washer as @pfrederi and @Achto but I use the parts cleaning solution from Tractor Supply. It works great and you don't have to put up with the mineral sperits odor. https://www.tractorsupply.com/tsc/product/crown-psc-1000-parts-cleaner-5-gal 4 Share this post Link to post Share on other sites
RJ Hamner 1,029 #8 Posted December 19, 2023 Anybody use or try Oil Eater?? I have been using it for several years now and it works great. Its a concentrate that you dilute with water. It says that it can be used the food processing equipment without a problem. I have used it in my parts washer and it both a trigger spits bottle as well as the mini pump up sprayer Amazon has it and some of the Tractor Supply stores carry it Just Sayin Bob 2 Share this post Link to post Share on other sites
pfrederi 20,183 #9 Posted December 19, 2023 I have tried it as a spray on but the Gunk Kerosene works better for me. 1 Share this post Link to post Share on other sites
RED-Z06 2,718 #10 Posted December 19, 2023 I use a 6 gallon ultrasonic off amazon, i put in 1/2gal simple green, 1/2gal zep citrus, 1/3gal Stages20, then top with water. I can clean for a long long time on that mix. 3 1 Share this post Link to post Share on other sites
