Sailman 1,143 #1 Posted December 12, 2023 All my tractors are workers so I do what is easy and cheap to keep them going. Rescued a 704 and wanting to get it running. Front rims were BAD shape and original replacements seem hard to come by so..... I do a lot of boat repairs with West System epoxies and fillers. One wheel had a hole a couple inches long where valve stem used to be and multiple pin holes. I had good luck with pin holes and JB Weld on my GT 14 so I used the West epoxy and fiberglass to patch the rim from the inside, then JB Weld to finish on the outside. I always use tubes in this configuration and have good luck with the results. Probably not what the purists would do but hey...sailor's got to do what a sailor's got to do! BEFORE; AFTER; 11 3 Share this post Link to post Share on other sites
ri702bill 7,486 #2 Posted December 12, 2023 20 minutes ago, Sailman said: I always use tubes in this configuration and have good luck with the results. Probably not what the purists would do but hey...sailor's got to do what a sailor's got to do! As long as the finished rim has very good structural integrity, good save. A perfect candidate for a tube. Much better that boosting one from an old wheelbarrow !! 1 Share this post Link to post Share on other sites
kpinnc 11,042 #3 Posted December 12, 2023 (edited) 1 hour ago, Sailman said: Probably not what the purists would do but hey...sailor's got to do what a sailor's got to do! I think that is a very good repair. My only "+1" addition would be to ask if the epoxy will stick to something that inhibits rust like red oxide primer or some other dry inhibitor? Either way, that should be a years-long fix! Edited December 12, 2023 by kpinnc 2 Share this post Link to post Share on other sites
8ntruck 6,502 #4 Posted December 12, 2023 The following probably falls into the garden tractor trivia catagory. In general terms, the steel wheels we use on our Horses are not a highly loaded item. The highest stressed area is probably the beadseat area, due to the inflation pressure in the tire. Operating loads, even on a heavily weighted machine, such as @ebinmaine runs, still are not very high. The low operating speeds mean that the dynamic loading is almost non-existent. This means that we can get away with using the type of repair @Sailman has described. Would I do that on a wheel to be used on a front end loader? NO. Would I try to repair a wheel with a huge hole in the beadseat this way? NO. Should I expect a repair like this to last forever? NO. Am I going to operate the repaired wheel on 'nice' terrain? OK. Will the repaired wheel be used on a machine that will not have many hours put on it? OK. Will the repaired wheel be used on a machine that will be operated by a youngster? That depends on the youngster. In my 40 year carreer as an engineer in the steel wheel industry, I've seen countless fatigue failures, some failures caused by overload, and a few impact failures. I've never seen a fatigue failure on a garden tractor wheel. Rust through and bending seem to be the common failure modes for garden reactor wheels. I will say that loose lug nuts will cause fatigue crack to originate in the bolt holes on any wheel, so keep an eye on your lug nut torque. 4 Share this post Link to post Share on other sites
Sailman 1,143 #5 Posted December 12, 2023 7 hours ago, ri702bill said: As long as the finished rim has very good structural integrity, good save. A perfect candidate for a tube. Much better that boosting one from an old wheelbarrow !! These old wheels are pretty heavy duty steel. Much stronger than any wheelbarrow wheel I have ever seen. Even with the epoxy repair I will lay a $100 bill it will outlive me. 1 Share this post Link to post Share on other sites
Sailman 1,143 #6 Posted December 12, 2023 6 hours ago, kpinnc said: I think that is a very good repair. My only "+1" addition would be to ask if the epoxy will stick to something that inhibits rust like red oxide primer or some other dry inhibitor? Either way, that should be a years-long fix! Can't say for sure about sticking to the primer. I took the rims down to metal as much as possible. I will say this....the west system epoxy repairs I have done on wood are so strong if you try to remove it, it will simply break the wood in a new place, not the bond. 1 Share this post Link to post Share on other sites
