ebinmaine 80,933 #1 Posted December 3, 2023 I want to order a few hair pins the size that fit the plow frame cross shaft at the rear mount. They're also used for many other places on a Wheelhorse. Old part number is 933506. Looks Toro superceded to 9335064. I see the length (on Jack's) is just over 3". What's the wire diameter? Share this post Link to post Share on other sites
peter lena 10,090 #2 Posted December 3, 2023 @ebinmaine those are called HITCH PINS , I was also calling them hair pin clips , like the 1/8 x 3 size and push them all the way to last large hole , they won't slide / fall out at that hold point . T/S usually has a good selection of those safety clips . pete Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,510 #3 Posted December 3, 2023 Possible sizes at a farm store https://www.princessauto.com/en/searchresults?Nr=product.active%3A1&Ntt=double ring r-pin*&Nty=1&No=0&Nrpp=50&Rdm=392&searchType=simple&type=search 1 1 Share this post Link to post Share on other sites
ebinmaine 80,933 #4 Posted December 9, 2023 On 12/3/2023 at 11:47 AM, gwest_ca said: Possible sizes at a farm store https://www.princessauto.com/en/searchresults?Nr=product.active%3A1&Ntt=double ring r-pin*&Nty=1&No=0&Nrpp=50&Rdm=392&searchType=simple&type=search I checked to see what the bin said we were using and ordered by that. I found a large quantity of 5/32 online. I like the zinc coated for corrosion resistance. Pricing is excellent. 2 Share this post Link to post Share on other sites
