Ricks 520 11 #1 Posted November 26, 2023 (edited) I have been working on a GT14 I got last summer as a basket case. Changed the fluid and the filter and did some other work to it. I took it out for a drive and it sounds good and the lifts go up and down fine but it has a whine in the transmission when it moves and only moving. Thought I would ask for ideas before I tear it down. Edited November 27, 2023 by Ricks 520 2 Share this post Link to post Share on other sites
Pullstart 71,353 #2 Posted November 26, 2023 Sometimes they whine. It’s best to warm it up, then chain it to a tree and stress that transmission. It should be able to spin the tires, forward and in reverse. If it is whining and it’s not turning tires then it’s a problem. @PeacemakerJack’s son Zach just redid a GT14 and this was a topic of discussion. 4 Share this post Link to post Share on other sites
PeacemakerJack 11,062 #3 Posted December 2, 2023 Rick-I’m not sure why the whine but Zach’s is working good so far. He pulled a furrow plow around Jim’s plow day for about 3 hours without any incident. In our case, we are just going to continue to use it until it starts lacking the lugging power that it currently possesses… 2 Share this post Link to post Share on other sites
peter lena 10,082 #4 Posted December 2, 2023 @Ricks 520, pay attention to any operational / changes / noise . better worse ? drive it reverse ? always found a rear end related noise / function is not a one and done , improvement . also use it in a total opposed drive function , yesterday had my horse , in a near by CUL DE SAC for backward motion , like to heat things up , open empty road , check oil color , might try a different fluid / additive ? just a suggestion . pete 1 Share this post Link to post Share on other sites
19richie66 17,937 #5 Posted December 2, 2023 We had hydrostats at work that whined for years. Sunstrand pumps in groundsmasters, we ran them till they wouldn’t move which usually was because of operator abuse. I would enjoy it for as long as it will last and possibly look for another pump. Never know, it may last another 20 years depending on use. The newer Eaton 1100 can be put in it but it’s a job. 1 Share this post Link to post Share on other sites
