DCwom 78 #1 Posted November 22, 2023 The hood latch on my Raider doesn't stay latched, its got those rollers which I assume simply pinch tight against the frame/dash. Any suggestions how to tighten up the latch? Share this post Link to post Share on other sites
Lee1977 7,459 #2 Posted November 22, 2023 2 hours ago, DCwom said: The hood latch on my Raider doesn't stay latched, its got those rollers which I assume simply pinch tight against the frame/dash. Any suggestions how to tighten up the latch? That 1/4" rod gets bent down, that may be what causes it to come lose. The holes in the hood may be worn. I had to patch mine the hole was almost 3/8" I made some 1/8" thick brackets and riveted them to the hood with small rivets that are used to hold ID plates. I also made a new 1/4" rod as the old one was in bad shape. 1 Share this post Link to post Share on other sites
