rustyedge1
417-8 WH seat change out for Ferris seat ??
rustyedge1
Looking at this Ferris seat and wondering about the issues I may encounter in trying to switch out entire seat on the 417 or even if it can be done ?
Any info would be appreciated and thanks in advance.44DA8189-0ADD-4570-BB45-09BF09326BF4.jpeg.42bf4f6bbf2f4efe728d0691995a320d.jpeg
Edited by rustyedge1
ebinmaine
First thing that comes to mind for me is to make sure you maintain the ability to tilt the seat forward to access the gas tank. That might seem obvious in statement but looking at the adjustment lever on the front of that newer seat you'll want to make sure that clears properly.
rustyedge1
Haven't bought the seat yet, was wondering if I could just use my old WH seat mount and do away with the Ferris brackets and such,
New seat is in an auction depending on how it goes money wise may be just something to play around with.
peter lena
@rustyedge1 never liked the heavily rear angled seat , also like a hi backed seat . drilled the front side mount holes , lower on the bracket , for more leg room under wheel . paint recovery site for rear seat springs, look at it from the side mount point , to get what you want , also expect to have to make up part of the base mount . the short springs I used are very stiff , but just right , pete
kpinnc
Thats a suspension system and slides for moving somewhat back and forth adjustment.
Any 300/400/500 series should have the flip up plate, and making that seat assembly bolt up to that plate shouldn't be difficult.
rustyedge1
That was also something i'll just have to see how it looks after I get it home, if I get it bought..
  • Similar Content
    • Monstrosity
      By Monstrosity
      Show off what your doing from the seat of your Horse!!! Fixed up a mowing deck for the 1277 and put the plow on the C1014. Getting ready to level a topsoil pile and going down the block to mow the small park to test the mowing deck out.
    • Ritter
      By Ritter
      Greetings All,
      Really nice site, and I am a new member.   As I kick back and eat my lunch,  I could not have imagined that Wheel Horse Tractor owners would have such a cool and well-organized place to ‘meet’ despite being out of production for so long.  My name is Ron and I have a 1979 C-81.   It has a WH pull-behind cart as well as a snow plow with chains, weights, etc..
      The tractor belonged to my grandfather, who purchased it new in 1979 for just over $1,100.00.  Some of my best memories are learning to drive it (barely reaching the pedals) and trying to understand the difference between the clutch and brake.   I believe at one point it had a lawn sweeper, which eventually just dragged and made skid marks across the lawn until it was retired.
      My grandfather drove this tractor year-round for 7 years until he passed away.  In the winter it was plowing and hauling logs to the house, in the spring it aerated,  fall it mulched, summer it mowed.   The C-81 always remained at his house and in my family.
      The most interesting part (or at least interesting to me) is that for the last 39 years, this mower has been in-service without missing one season.  It has never been out of commission.   To this day, we have it picked up for service every year and it is still running on its original 8hp Kohler Engine and cuts just over an acre of lawn.  The only major replacements were pulley bearings for the blade deck and a starter motor.   It is ultra-quiet and never strains while performing its tasks. So, when you look at the picture,  you probably see a beat up old machine, but I can assure you that is a tried-and-true Wheel Horse used year-round for nearly 4 decades and maintained as best we thought possible.  It’s a testament to a reliable and powerful brand.
      That said,  I have decided to lessen the workload on this machine and perhaps get another Wheel Horse as a tribute to my Pop.    The main issue is that the cutting deck on this machine is between 32-34” (I believe) and it takes a long time to cut the lawn.  (although I enjoy the peaceful feeling of doing it, it’s not conducive with my day job).   The secondary issue is that this is a rear-discharge deck.  I’d like to somehow bag the clippings for most of my cuts in order to feed my mulch/compost pile.   I’m open for suggestions as to what model would be best.   I do have some hills (a few steep).
      One final note…
      I’d love to crown this C-81 with a new (or comparable) seat.   My goal is to get one as close to original as possible, with the same bolt patterns.  I can provide photos if needed.  Any help would be appreciated.   Again, glad to be a part of this community, and please bear with me as I get used to navigating this site.
      Thanks for reading.
    • SOCKDOG
      By SOCKDOG
      I have a 1963 633 with the steal Square pan seat. It is cracked and looking to replace it. I can find loads of the standard round replacement seats but not a square one. Does anybody know where I can find one?
    • Vixmith
      By Vixmith
      I would appreciate recommendations for a replacement seat for my 1990 520H. Original seat has several holes and sponge sticking out. Big problem is me sliding sideways when mowing along a slope. Thanx for the help.
    • Team70R
      By Team70R
      I've seen plenty of rear mount cranes/booms but has anyone ever seen or built a front mount?? I know the front tires will take more abuse but I feel like the tractor will be more balanced if the crane is on the front
      wes
