Pat Marchwick 94 #1 Posted November 6, 2023 I was putting on the single stage snowblower today and instead of washers I put a split collar clamping stop on the 3/4” diameter shaft that slides inside the lift tube. Works great and much easier to adjust the lift height. they cost no more than $10.00 depending where you buy them 3 5 1 Share this post Link to post Share on other sites
moe1965 774 #2 Posted November 6, 2023 Now that's a cool idea. 1 Share this post Link to post Share on other sites
peter lena 10,089 #3 Posted November 7, 2023 @Pat Marchwick always think about possible movement areas / improvements , verify function / movement , thats where you change / lubricate , improve a trouble spot . can't tell you how many movement areas I have , improved on , typically , sloppy fit , make a problem a solid changing gain , like a HEIM JOINT in place of a trunnion , never had a failure , pete 1 Share this post Link to post Share on other sites
ebinmaine 80,930 #4 Posted November 7, 2023 Well done Pat! Got any pics of the location? Some of us children really enjoy our pictures ya know........ Share this post Link to post Share on other sites
