leabassett@sbcglobal.net 156 #1 Posted October 18, 2023 Anyone know if rear wheels off a 1972 Cub Cadet will fit my 1987 312-8? They are 23X8.5X12. My horse has one rear that goes flat every few days and the cub holds air for ever. 1 Share this post Link to post Share on other sites
ri702bill 9,176 #2 Posted October 18, 2023 Pictures???? Or, install a tube.... most of us do............. 2 Share this post Link to post Share on other sites
ebinmaine 71,734 #3 Posted October 18, 2023 The back spacing on Wheelhorses is different from most others. More shallow. Other brand wheels can be used but some require the installation of spacers which usually removes a good value for using the non Horse wheels. I'd second the usage of a tube to solve the leak. 2 Share this post Link to post Share on other sites
953 nut 59,106 #4 Posted October 18, 2023 9 minutes ago, leabassett@sbcglobal.net said: Anyone know if rear wheels off a 1972 Cub Cadet will fit my 1987 312-8? They are 23X8.5X12. My horse has one rear that goes flat every few days and the cub holds air for ever. Bolt pattern would be the same, all depends on the backspacing of the rim. @ebinmaine beat me. 1 2 Share this post Link to post Share on other sites
Handy Don 13,619 #5 Posted October 18, 2023 27 minutes ago, ebinmaine said: I'd second the usage of a tube to solve the leak. Make sure to thoroughly wipe the inside of the tire with a rag before tubing it to make sure any debris that could puncture the tube has been removed. Also check for rough spots on the rim. Same reason. 2 Share this post Link to post Share on other sites
leabassett@sbcglobal.net 156 #6 Posted October 18, 2023 I know I could get a tube and have done it in the past, Just feeling cheap and what to use what I all ready have. 4 Share this post Link to post Share on other sites
Handy Don 13,619 #7 Posted October 18, 2023 2 minutes ago, leabassett@sbcglobal.net said: use what I all ready have Yep, good plan! 2 Share this post Link to post Share on other sites
Lee1977 7,111 #8 Posted October 19, 2023 There isn't much room between the tires and the gas tank on a 312-8 with stock wheels. - 3 Share this post Link to post Share on other sites
Sparky-(Admin) 22,742 #9 Posted October 19, 2023 The offset will be wrong and the Cub tires will rub or be right up against the fender/fuel tank supports. And for sure you will never be able to to run chains. I wouldn’t bother buying those Cub wheels. Find a small-engine shop and have a tube installed (or install it yourself) Share this post Link to post Share on other sites
TonyToro Jr. 1,840 #10 Posted October 19, 2023 56 minutes ago, Sparky said: The offset will be wrong and the Cub tires will rub or be right up against the fender/fuel tank supports. And for sure you will never be able to to run chains. I wouldn’t bother buying those Cub wheels. Find a small-engine shop and have a tube installed (or install it yourself) also, the hole in the center of the Cub wheels are a lot smaller the the holes in the WH hub. So you would need to get wheel spacers. And then the wheels would be brought out wider. (We learned it the hard way with my pulling tractor) Share this post Link to post Share on other sites
rjg854 12,008 #11 Posted October 19, 2023 (edited) I have CC wheels on my C160, which is my plow tractor in winter. I have no problem with the chains on the tires, and I don't use spacers. Center hole is the right size to fit the hub. The main difference in my case was the valve stem is on the outside. Which is why I have wheel weights for a D series on the wheels. Edited October 19, 2023 by rjg854 add Share this post Link to post Share on other sites
Lee1977 7,111 #12 Posted October 19, 2023 2 hours ago, rjg854 said: I have CC wheels on my C160, which is my plow tractor in winter. I have no problem with the chains on the tires, and I don't use spacers. Center hole is the right size to fit the hub. The main difference in my case was the valve stem is on the outside. Which is why I have wheel weights for a D series on the wheels. The C-series has a lot of room behind the wheels, it's the gas tank on the 312 that's in the way. Share this post Link to post Share on other sites
leabassett@sbcglobal.net 156 #13 Posted October 19, 2023 I have the cub now. If I do not sell it I will be using as many parts as I can off of it. Share this post Link to post Share on other sites
