peter lena 9,555 #1 Posted October 14, 2023 like rust ? don't use this on it , https://www.homedepot.com/p/CRC-3-36-Multi-Purpose-Lubricant-and-Corrosion-Inhibitor-03005/300533394?irgwc=1&cm_mmc=afl-ir-78091-1155214-&clickid=VsRVTD3OrxyPR3cSNeRflzDIUkFT24yVwwRYRI0 , its quick oil creeping , is telling you something . very easy to use / apply , look at newer cars / trucks with the rust starting . easy to prevent . oily pete 1 Share this post Link to post Share on other sites
peter lena 9,555 #2 Posted October 14, 2023 @JoeM been rustproofing my stuff , most of my life , basically its lubrication stopping rust . like a lighter weight creeper penetrant , first in every closed crevasse , seam . joint . thats your base of protection . next go over it with a heavier , open gear spray , lubricant , that will seal itself to the lighter lube . don't have any rust / rot . visual checks to areas treated , areas , show a black tar like finish , every seam , fender well , doors , tailgates , suspension is rust free. wash my cars , and always under spray , asap. doing it for so long , just do it . amazing to me to see fairly new trucks , rotted out . my son just did a 2 gallon mineral oil , soak on a Mercedes , gear oil over spray , last a very long time , doors drip oil , Burlington Vermont , zero rust , pete Share this post Link to post Share on other sites
