AHS 1,703 #1 Posted October 7, 2023 I got a Wheelhorse for $50!!!!! A B80, its an 8 speed…. so it must a 76 or a 77? 71-08k801 14413 and the number below it is 7094… i think!! All factory wiring and coil. It looks like the PTO seal is bad..oil all over the place! We’ll see once i get it running!! I changed the oil and gas came running out.. cute!! Hopefully clean the carb, set the points and new fuel line/filter.. and it’ll be a runner!!! 5 3 Share this post Link to post Share on other sites
Racinbob 13,290 #2 Posted October 7, 2023 The 71 prefix indicates it's a 77. 76's and 77's are identical though. The B series and C series Are identical in those two years save for some cosmetic items and HP. Here's my 76 B-80 that I purchased new and still have it. It grew into a "B"-160. 1 3 Share this post Link to post Share on other sites
ebinmaine 81,289 #3 Posted October 7, 2023 I'm really happy to see you got that! Now that machine can be maintained like it should be and put to work. You'd really like the little 8 HP engine. Economical and powerful for its size. That's a... uhhh... nice seat ((??)) 2 Share this post Link to post Share on other sites
AHS 1,703 #4 Posted October 7, 2023 40 minutes ago, ebinmaine said: I'm really happy to see you got that! Now that machine can be maintained like it should be and put to work. You'd really like the little 8 HP engine. Economical and powerful for its size. That's a... uhhh... nice seat ((??)) Ya.. the seats gonna be the most expensive item!! 1 Share this post Link to post Share on other sites
ebinmaine 81,289 #5 Posted October 7, 2023 4 minutes ago, AHS said: Ya.. the seats gonna be the most expensive item!! You might be able to find a decent used one? 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,898 #6 Posted October 7, 2023 The B-80’s are great rigs. I work mine and take it to shows. 5 4 Share this post Link to post Share on other sites
J854D 145 #7 Posted October 7, 2023 @AHS, the 7094 number in your serial number is the Julian date of manufacture. Meaning your B80 was built on the 94th day of 1977. (Monday April 4, 1977). -JD- 2 Share this post Link to post Share on other sites
Retired Wrencher 7,046 #8 Posted October 7, 2023 I have one for plow duty. Most the time it just sits in the garage. Like Mike said hard to beat these K181`s. 1 1 Share this post Link to post Share on other sites
Moparfanforever 940 #9 Posted October 7, 2023 LB for LB ,the 8HP Kohler is hard to beat !! 2 Share this post Link to post Share on other sites
AHS 1,703 #10 Posted October 7, 2023 6 hours ago, J854D said: @AHS, the 7094 number in your serial number is the Julian date of manufacture. Meaning your B80 was built on the 94th day of 1977. (Monday April 4, 1977). -JD- Oh! Now i know when the B80s birthday is!! 1 Share this post Link to post Share on other sites
AHS 1,703 #11 Posted October 7, 2023 Ok, I drained the oil…gas in the oil. A lot of gas! The gas tank is completely dry… what if the needle was stuck open and drained into the base? I changed the oil. I cleaned the points and replaced the spark plug and sprayed starting fluid into the carb..and it did run!! Now to take off the carb. I guess i will see what the carb holds!! 1 Share this post Link to post Share on other sites
ebinmaine 81,289 #12 Posted October 7, 2023 21 minutes ago, AHS said: Ok, I drained the oil…gas in the oil. A lot of gas! The gas tank is completely dry… what if the needle was stuck open and drained into the base? I changed the oil. I cleaned the points and replaced the spark plug and sprayed starting fluid into the carb..and it did run!! Now to take off the carb. I guess i will see what the carb holds!! Quick rebuild kit in that carb and also check the fuel pump. 1 Share this post Link to post Share on other sites
AHS 1,703 #13 Posted October 7, 2023 7 hours ago, Retired Wrencher said: I have one for plow duty. Most the time it just sits in the garage. Like Mike said hard to beat these K181`s. I had a 76 B80, mine was for plow duty. It boggles my mind how the K181’s would work!! AND even use such little gas!! I sold the 76 to a friend, he and the tractor only live about a mile from me. I got rid of my 76 in May ‘23 and i got a 77 B80 in October! 1 Share this post Link to post Share on other sites
rjg854 13,456 #14 Posted October 7, 2023 I'm with Eric, check that fuel pump. A leaking diaphragm is how gas gets into the crankcase. 2 Share this post Link to post Share on other sites
AHS 1,703 #15 Posted October 8, 2023 (edited) 1 hour ago, rjg854 said: I'm with Eric, check that fuel pump. A leaking diaphragm is how gas gets into the crankcase. Ok. I have found a rebuild kit for the metal fuel pumps Edited October 8, 2023 by AHS Mis spell 1 Share this post Link to post Share on other sites
ebinmaine 81,289 #16 Posted October 8, 2023 Just now, AHS said: Ok. I hate replacing fuel pumps, those cheap Chinese plastic ones! You can likely rebuild the old metal one Share this post Link to post Share on other sites
Jon Paulsen 291 #17 Posted October 8, 2023 A leaking needle valve in the carby can ruin the crankshaft's day Note: I have never had a Kohler engine, so as usual, take anything I say with a grain of salt, ya old salt Glad you gotcha a nice new toy. And, of course: FLY NAVY! 1 Share this post Link to post Share on other sites
Retired Wrencher 7,046 #18 Posted October 8, 2023 11 hours ago, AHS said: I had a 76 B80, mine was for plow duty. It boggles my mind how the K181’s would work!! AND even use such little gas!! I sold the 76 to a friend, he and the tractor only live about a mile from me. I got rid of my 76 in May ‘23 and i got a 77 B80 in October! Those are easy to find.These are the 60`s tractors 10 to 15 years ago. Easy to maintained.Enjoy the ride. 1 Share this post Link to post Share on other sites
moe1965 774 #19 Posted October 8, 2023 Nice find and it's always fun for me to find a tractor that needs some TLC to get it running and find and fix all the little issues it may have. It's what I like to do. My issues is I never than wanted to sell them I get to attached 😄. Have fun 1 Share this post Link to post Share on other sites
WheelHorseNut 222 #20 Posted October 10, 2023 On 10/7/2023 at 6:57 AM, AHS said: Ya.. the seats gonna be the most expensive item!! I got a decent replacement seat, for my B80, from Northern Tool. It was $70 I think. I love my B80 -- fun tractor. I got mine for about $50, too. It wasn't running and had a snow blower on it and came with a rotted out mower deck. I changed the oil, new gas, new plug with proper gap and boom, she fired right up! Nice and easy to work on. Good luck with yours! 1 Share this post Link to post Share on other sites
