Winkster 12 #1 Posted October 3, 2023 Hi folks; Recently got the answer from you guys and replaced condenser and spark plug. 1977 C120 12hp Kohler. Started right up but began backfiring after awhile.. Wet long grass and some hills. I'm thinking carb adjustment but unsure how many turns if I screw both all the way in. Thanks yet again. Winkster Share this post Link to post Share on other sites
Daddy Don 912 #2 Posted October 3, 2023 I had the same problem with mine thought it was the carb did what your doing and it did not fix the problem. Replace the spark plug and it took car of the problem. Hope this might help you out. 1 Share this post Link to post Share on other sites
Ed Kennell 46,197 #3 Posted October 3, 2023 9 hours ago, Winkster said: but unsure how many turns if I screw both all the way in. If you back them out 1.5 turns it should run. Then make fine adjustments to get best performance. 1 3 Share this post Link to post Share on other sites
953 nut 66,551 #4 Posted October 3, 2023 11 hours ago, Daddy Don said: Replace the spark plug and it took car of the problem. Hope this might help you out. Did you replace the spark plug with a new Champion H-10? Here is a chart with the proper adjustments for carburetors . 2 1 Share this post Link to post Share on other sites
Handy Don 16,751 #5 Posted October 3, 2023 2 hours ago, 953 nut said: Just a word of warning. This applies to original and OEM carbs. Aftermarket and 3rd party carbs may have different thread pitches on the needle valves--typically more coarse threading. So far, every aftermarket carb I’ve installed came ready to run and I’m glad I did not mess with the needle valves before trying to start it. I only discovered the difference when I went to clean one a year or so later. Also, when getting ready to remove a needle valve, ALWAYS gently screw it in to the stop and write down the number of turns so you can put it back the way it was on reassembly! 4 Share this post Link to post Share on other sites
Daddy Don 912 #6 Posted October 4, 2023 I will look and make sure what the plug number is. 1 Share this post Link to post Share on other sites
953 nut 66,551 #7 Posted October 4, 2023 21 hours ago, Handy Don said: o far, every aftermarket carb I’ve installed came ready to run I've only bought two Chinese carbs and they were both junk. One was a 26 mm throttle bore (ten to twelve horsepower) but was jetted for a fourteen to sixteen horsepower engine and couldn't be adjusted properly. I replaced the main jet seat and needle with ones from the old carb and it ran OK but nothing worth bragging about. The second one (I bought both at the same time to save on shipping) had a throttle plate that wouldn't close all the way, it went into the circular file! 1 Share this post Link to post Share on other sites
Sailman 1,307 #8 Posted October 4, 2023 (edited) 8 minutes ago, 953 nut said: I've only bought two Chinese carbs and they were both junk. I bought a small used Yamaha 50cc motorcycle for my grand kids to learn how to ride. Had trouble keeping it running and no matter how much I adjusted the after market carb, nothing changed. Disassembled it and found both low speed and high speed adjustments.....were not even functional! Just for show. Replaced the chinese junk with an OEM. Edited October 4, 2023 by Sailman 1 1 Share this post Link to post Share on other sites
Handy Don 16,751 #9 Posted October 4, 2023 So clearly I’ve been lucky with the three carbs I’ve gotten (snowblower, tractor, chain saw) Do I quit while ahead or keep going? 1 Share this post Link to post Share on other sites
Daddy Don 912 #10 Posted October 4, 2023 18 hours ago, Daddy Don said: I will look and make sure what the plug number is. Plug # is BPR7HS NGK R Share this post Link to post Share on other sites
pfrederi 20,657 #11 Posted October 4, 2023 1 hour ago, Daddy Don said: Plug # is BPR7HS NGK R H10 c or Autolite 216 or NGK B-6L Share this post Link to post Share on other sites
Daddy Don 912 #12 Posted October 8, 2023 Did you get your WH working okay? Share this post Link to post Share on other sites
Jon Paulsen 291 #13 Posted October 9, 2023 I'ma gunna pass on this deal: https://www.sparkplug-crossreference.com › convert › NGK_PN › BPR7HS NGK BPR7HS - Alternative spark plugs - Spark plug cross reference NGK BPR7HS - Alternative spark plugs. There are 60 replacement spark plugs for NGK BPR7HS . The cross references are for general reference only, please check for correct specifications and measurements for your application. Specifications for NGK BPR7HS. Thread diameter: 14mm. Thread reach: 12.7mm. Seat type: flat. Hex size: 21mm. Share this post Link to post Share on other sites
