Dennis C. 142 #1 Posted September 30, 2023 I have a 1996 314H with a 42" deck. Will the standard 2 bagger attachment work with this deck or do i need the powered type bagger? Also, do you need special blades when using the un-powered bagger? Thanks in advance. Share this post Link to post Share on other sites
Darb1964 1,151 #2 Posted September 30, 2023 I have that set up on my 312-A with the power loader run by a small BS. I bought the entire package used few years ago and it works fine, although I need to change the BS. It has low oil protection and on a side hill it stops running, put a little extra oil in it it blows out the air filter. Was a replacement by PO. Not right for that setup. You would need high lift blades without loader, I also have a high lift set up on a much smaller deck and bagger that works OK need to go slow in heavy grass and leaves. The bigger deck not sure how that would perform with just high lift blades. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,017 #3 Posted September 30, 2023 79301 was the collection system available for the 42" SD deck in 1996 https://www.wheelhorseforum.com/search/?q=79301&quick=1&type=downloads_file 1 Share this post Link to post Share on other sites
Dennis C. 142 #4 Posted September 30, 2023 32 minutes ago, Darb1964 said: I have that set up on my 312-A with the power loader run by a small BS. I bought the entire package used few years ago and it works fine, although I need to change the BS. It has low oil protection and on a side hill it stops running, put a little extra oil in it it blows out the air filter. Was a replacement by PO. Not right for that setup. You would need high lift blades without loader, I also have a high lift set up on a much smaller deck and bagger that works OK need to go slow in heavy grass and leaves. The bigger deck not sure how that would perform with just high lift blades. Thanks for the info. Saved me a un-neccessary road trip. Guess I'll buy a sweeper instead. Those powered baggers are not easy to come by Share this post Link to post Share on other sites
Dennis C. 142 #5 Posted September 30, 2023 23 minutes ago, gwest_ca said: 79301 was the collection system available for the 42" SD deck in 1996 https://www.wheelhorseforum.com/search/?q=79301&quick=1&type=downloads_file Thanks!! Share this post Link to post Share on other sites
