Donavon
What is the heaviest model wheel horse?
Donavon
Just curious what is the heaviest for a future project.
8ntruck
I'd guess it is one of the D series.  Those were sort of a precursor to the current mini tractors.
c-series don
The D-250 I’d say.
Rick3478
22 minutes ago, c-series don said:
The D-250 I’d say.
That was my first thought, but then I wondered what about the 520 aircraft tug?
kpinnc
My response to the question may ruffle feathers, but it's not my intention to offend. I'm also not a purist, but this is how my tiny brain works. :rolleyes:
The heaviest were (unless the senior owners can give bigger numbers) the DXI series, at just over 1100lbs. The GT-14 follows at nearly 900lbs.The D-250 was a rebadged German manufactured Gutbrod.
And... the D series machines were completely different from the traditional line of tractors that began with the RJ and ended with the last run of Classics in 2007. That entire line of tractors are similar from the ground up, and more of an evolution of a core design.
So- while D series tractors wore the name, at best they were offshoots that were intended to penetrate a different market while leveraging the WH reputation. The D-160, 180, and 200 were released after Wheel Horse sold to AMC. How much design work of them originating from Wheel Horse is not clearly defined. The transmission was about the only thing they had in common with other tractors of the period. The XI series machines are excellent tractors, while also almost 100 percent Toro creations. New Holland also sold rebadged XI models.
Almost no implement made for D series would work with the classic line. The same was true for the GT-14 and many XI series.
So MY "way too long" answer would be the heaviest Wheel Horse was the GT-14 at over 900lbs, then the C-195 at 740lbs, followed by the 520-H (also heavily influenced by Toro) at around 650lbs. Toro designed the later model 60 inch deck as well, so I can't include that if going by my own exclusions. If so, it would be an additional 300lbs. Maybe if the two stage snowblower was attached?
Edited by kpinnc
  • Excellent 2
ebinmaine
Along the lines of thinking about a heavy Wheelhorse my first question is,
For what?
What project?
What purpose?
ANY Wheelhorse can be made Heavy.
Add steel. Add fluid.
It's very easy to make a 70s C Series tip the scales at over 1000 lbs before any implements are installed.
ri702bill
Is that with or without The Bear....???  :laughing-rofl:
ebinmaine
No Bears included.
Add 260+.
BairleaFarm
10 hours ago, c-series don said:
The D-250 I’d say.
Wasnt the D250 not really a Wheel Horse but a GT made my renault that was branded Wheel horse?
953 nut
image.png.86e36702e2f438aebc1bc5040ea759d5.pngTake a GT-14, add a  front end loader with weight box, a York rake, WW93 wheel weights and liquid filled tires and you are up to about 1,800 pounds without the operator. Have @ebinmaine gat in the seat and you are over a ton of Wheel Horse fun.    :handgestures-thumbupright:
Edited by 953 nut
  • Haha 5
  • Heart 1
Rick3478
Speaking of AMC, wasn't there a WH branded Jeep?  Where did I see that?  Maybe it was just a one-off paint job for advertising.  My brain sometimes regurgitates useless information, too. :lol:
kpinnc
Add ME! :lol:
Yes you can nearly double the weight of these machines. Weights, fluids, heavy implements.
That's what I was concerned with my earlier post- often times reported weights come from a machine with an implement attached, rather than what I would call a "dry weight" with nothing added.
Lee1977
Then there are the electric battery powered tractors. Originally design and built by GE, Elec Trak E20 the largest having 3.5 electric motor ( equivalent to 14, later model clamed 16 gas HP ) 36 volts  85 amps with 6 -6 volt batters
850 lbs.
Edited by Lee1977
Thor27
Got me curious, so looked up some of the bigger horse weights on tractordata.
D-250  1160#
523dxi. 1150#
D-200.  1025#
C-185.   894#
GT-14.   875#
E-141.    825#
C-195.    740#
evanloock
As the D-series were based off the 18-Automatic introduced in 1973, I would say they are a Wheel Horse design.  As with every other new design I am sure it was on the engineer's drawing board a year or more before the production 18-Automatic was offered for sale.  The D-250 is definitely not a "true" Wheel Horse.  RS-83/Senior flyer states that it weighed 810 pounds without ballast in the tires.
Edited by evanloock
Donavon
For what?
What project?
What purpose?
I'm wanting to make a custom wheel horse tandem axle tilt bed
ebinmaine
THAT would be neat.
If you're not looking for any particular shape or model,
IMHO...
Your best bet would be something quite common with great parts availability that isn't yet to the collectible stage.
The 300, 400 series are plentiful and just as rugged as any other past models.
19richie66
14 hours ago, ebinmaine said:
THAT would be neat.
IMHO...
Agreed. I would stay away from a D series if you plan to stretch it any without doing a serious drivetrain change. Don’t ask me how I know.:hide:
Edited by 19richie66
pfrederi
:text-yeahthat:
D 200 are not very nimble to start with... longer wheelbase will only make it worse....
kpinnc
10 hours ago, 19richie66 said:
The heaviest Wheelhorse ever made was the one that won’t start that you have to push by yourself so you can get to something in the back of the shed.
Don't forget the one with a flat tire when you have no way to pump it up! :P
  • Haha 2
Donavon
I am planning to stretch it, the biggest thing I would possibly haul on it would be my Dixie chopper
  • Similar Content
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get an engine swap.
      Thanks,
      John
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor! Starts right up and Runs and Cuts like a Champ!
      ONLY 419hrs
      FEATURES:
      Newer Agro Tires on Rear & Solid Front Turf Tires.
      Wheel Weights on rear.
      Fully Swapped Forward Swept axle and Steering off of 520h.
      New Tractor Supply Adjustable Seat.
      Exhaust Fully Restored. (Sandblasted, Outgassed and 2000deg High Temp Satin Exhaust Paint Coated.)
       I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      Asking >>>>> $1,099 OBO <<<<<<<
      (248) 943-8634 Text or Call.  God Bless.
    • Little Red Horse
      By Little Red Horse
      I am selling a 1970 Wheel Horse Electro 12. It is in *working condition*.
      It has AG tires and a mid-mount blade from wheel horse.
      It also has a front mounted generator that currently doesnt put out power. It has been in the barn quite a while, so it may be a corroded connection,  not sure. Although there's not too much that goes wrong with them.
      The tractor has been a great one for me. The last 6ish 7ish years that I've had it where I lived it brought the gravel back up my driveway for me every time it rained. In the last few months, it would run for 20-30min then die.
      I was moving at the time so just didn't have the time to look at it. And it seems I still don't. Where I am currently I don't have a place for it. I don't want it setting out and deteriorating. So here we are.
      Please contact me by text or email.
      Thanks for looking!
    • ohiofarmer
      By ohiofarmer
      i know that there is ebb and flow with market conditions, but I have been seeing bargain 520 and c-160 prices more common. I recently saw a c-160 like model on a place other than here that was close by, but i did not get a chance to see it as I was still on a medical tether getting care. i say c-i60 like model because it was a series of numbers like 4455 or somesuch .Tractor had the k series engine clearly a sixteen HP and came with a decent looking deck and pusher blade. i called my buddy Jay and told him for the $250 ask , he better hustle after it. i really do not know if he did.
        I also have been seeing 520s and such lower than I can remember as well as the D series..My theory is that people experiencing paycheck to paycheck living are increasing in number.
      You even are seeing a lot more older trucks like square bodies and especially big blocks than you did before. we used to see this a lot in new trucks when fuel prices hit records.
      i am not claiming expert status on this, but it seems to be trending this way one county next to indiana and 90 miles North of the Ohio River.
       Tell me what you are seeing out there and what you think.
           Edit:  Jay and I ran up to buy Bob Ellison's tractor in MI.  Bob was very nice to deal with and included his "last seat"   I got super lucky buying my first C-160 that did not start and another one shortly dropped in to keep it company. The tractor described above was listed for only two days and was gone
    • Rob R
      By Rob R
      Hi Guys, has anyone put the 3/4 inch Thrust steering bearings on your Wheel Horse Tractors. I recently did an install for a customer on a John Deere and i have to admit was easy to do and no mods required. My biggest concern will the thrust bearing fit and the will stock top clip fit back on with no mods . Thanks
